Mishimoto 370Z 350Z radiators, hoses, thermostats, etc
Vendor - Former Vendor
You can always count on us for some great deals on Mishimoto products for your 350Z or 370Z. Most products in stock and ship for free within 1 business days unless of course we run out.
PM us for great deals or check out our site.
Our Nissan 350Z & 370Z product listings:
Mishimoto Air Diversion Plates
The Mishimoto Nissan 350Z Air Diversion Plate is not only intended to enhance the aesthetic appeal of your engine, but will incomparably reduce your radiator’s coolant temperature. Every Mishimoto air diversion plate is constructed of 5052 aluminum and are available in several finishes.
Mishimoto Air Diversion Plate Nissan 350Z Aluminum; 03-06
Radiator Hoses
Mishimoto silicone Nissan 350Z radiator hose kits are made with a dual layer combining high grade silicone and heat-resistant embedded fibers to provide efficient heat reduction and increased pressure tolerance, all with an OEM replacement fit! Perfect for your Subaru WRX.
Mishimoto Radiator Hose Kit Nissan 350Z Black; Silicone; 03-06
Mishimoto Radiator Hose Kit Nissan 370Z Silicone;
Mishimoto Radiator Hose Kit Nissan 350Z Silicone; 07-08
Thermostats
Mishimoto Thermostat Nissan 350Z 62C; 03-08
Mishimoto Thermostat Nissan 370Z 66C;
Radiators
The Mishimoto performance aluminum radiator for the Nissan 350Z & 370Z is designed and engineered to maximize cooling efficiency by up to 30%, boost engine functions, and most importantly protect your car from overheating. It is the ideal upgrade to the stock Subaru radiator whether you drive your vehicle daily or take it for track runs.
Mishimoto Radiator Nissan 350Z Aluminum; 03-08 w/ M/T; Use Mishimoto Transmission Cooler for Models w/ A/T
Mishimoto Radiator Nissan 350Z Aluminum; 07-09
Our Universal DIY product listings:
Mishimoto produces several silicone couplers in variety configurations and sizes. Whether you are looking for a transition, straight, or angle, Mishimoto has the perfect silicone coupler for you. Their silicone couplers are made from the same heat-resistant embedded fibers as their silicone hose kits, so you know they are durable and can withstand the toughest conditions. Don't forget to get matching Mishimoto t-bolt clamps as well. If you don't see a particular hose, don't hesitate to PM us.
Mishimoto T-Bolt Clamp 1.5'' Universal Stainless Steel; 1.5''; Range: 1.42'' (36mm) to 1.57'' (40mm);
Mishimoto T-Bolt Clamp 2.25'' Universal Stainless Steel; 2.25''; Range: 2.12'' (54mm) to 2.44'' (62mm);
Mishimoto T-Bolt Clamp 2.5'' Universal Stainless Steel; 2.5''; Range: 2.36'' (60mm) to 2.67'' (68mm);
Mishimoto T-Bolt Clamp 2.75'' Universal Stainless Steel; 2.75''; Range: 2.6'' (66mm) to 2.91'' (74mm);
Mishimoto T-Bolt Clamp 2'' Universal Stainless Steel; 2.0''; Range: 1.89'' (48mm) to 2.12'' (54mm);
Mishimoto T-Bolt Clamp 3.5'' Universal Stainless Steel; 3.5''; Range: 3.38'' (86mm) to 3.7'' (94mm);
Mishimoto T-Bolt Clamp 3'' Universal Stainless Steel; 3''; Range: 2.87'' (73mm) to 3.19'' (81mm);
Mishimoto Silicone Coupler 2.0-2.25'' Transition Universal Silicone; 2.0-2.25'' x 3.0'' StraightTransition;
Mishimoto Silicone Coupler 2.0-2.5'' Transition Universal Silicone; 2.0-2.5'' x 3.0'' StraightTransition;
Mishimoto Silicone Coupler 2.0'' 90 Degree Elbow Universal Silicone; 2.0'' x 3.0'' 90 Degree Elbow;
Mishimoto Silicone Coupler 2.25-2.5'' Transition Universal Silicone; 2.25-2.5'' x 3.0'' StraightTransition;
Mishimoto Silicone Coupler 2.25'' Straight Universal Silicone; 2.25'' x 3.0'' Straight;
Mishimoto Silicone Coupler 1.25'' Straight Universal Silicone; 1.25'' x 2.5'' Straight;
Mishimoto Silicone Coupler 1.5'' Straight Universal Silicone; 1.5'' x 2.5'' Straight;
Mishimoto Silicone Coupler 2.5-2.75'' Transition Universal Silicone; 2.5-2.75'' x 3.0'' StraightTransition;
Mishimoto Silicone Coupler 2.5-3.0'' Transition Universal Silicone; 2.5-3.0'' x 3.0'' StraightTransition;
Mishimoto Silicone Coupler 2.5'' 45 Degree Elbow Universal Silicone; 2.5'' 45 Degree Elbow;
Mishimoto Silicone Coupler 2.5'' 90 Degree Elbow Universal Silicone; 2.5'' x 3.0'' 90 Degree Elbow;
Mishimoto Silicone Coupler 2.5'' Straight Universal Silicone; 2.5'' x 3.0'' Straight;
Mishimoto Silicone Coupler 3.0'' 90 Degree Elbow Universal Silicone; 3.0'' x 3.0'' 90 Degree Elbow;
Mishimoto Silicone Coupler 3.0'' Straight Universal Silicone; 3.0'' x 3.0'' Straight;
Radiator Hoses
Thermostats
Radiators
xirtam
Oct 3, 2015 02:06 PM
