FS: RC750cc, TurboXS: Utec, Boost controller, Map switch/ sensor
Old Feb 3, 2012 | 01:11 PM
psychoballistic's Avatar
psychoballistic
Default RC750cc, TurboXS: Utec, Boost controller, Map switch/ sensor
Ok, so I was planning on boosting another Z after all my upgrades and keeping the second stock block, but my plans have changed and now I am getting rid of a bunch of stuff.
Currently I have a set of RC 750cc Injectors with clips which worked flawlessly for me. Dropped to $250 from $300
Also, I have a TurboXS Utec, with a map switch, map sensor, and boost controller. I have the boost controller setup directly with the utec to have one system run everything. It is a great base tune for 750cc injectors on a stock motor. Also included is the serial cable for tuning, and some other cable that came with it when I purchased which I never looked at or touched, you get it too. For the three blue plugs off the back of the utec, I made connectors in case the unit had to ever come in and out of the car for whatever reason, v.s having the map sensor wires getting stressed on. Price dropped to $375!!!
I also have my first 18g FMIC which works great, a few bent fins and the bottom rail a little bent, but held boost up to 21lbs just fine. If interested, pm and I'll get ya photos of that.
My email is the fastest way to reach me, philipg103@gmail.com
Old Feb 6, 2012 | 09:40 AM
psychoballistic
Monday bumper
Old Feb 8, 2012 | 08:26 AM
psychoballistic
Bump, make me offers guys, I need these gone.
Old Feb 13, 2012 | 07:33 AM
psychoballistic
Bump, any offers?
Old Feb 16, 2012 | 07:04 AM
psychoballistic
Prices dropped!!!
Old Feb 27, 2012 | 05:11 AM
psychoballistic
Bump
Old Feb 27, 2012 | 05:22 AM
psychoballistic
Utec dropped to $375!!! for everything.
Old Feb 27, 2012 | 10:40 AM
Z3RO2N0N3's Avatar
Z3RO2N0N3
Question
what do you mean for everything? do you mean everything that comes with the utec or with injectors just want to clarify im wondering
Old Feb 28, 2012 | 10:04 AM
FineWine's Avatar
FineWine
Would you be willing to part with the clips by chance?
Old Feb 29, 2012 | 05:56 AM
psychoballistic
Everything that comes with the utec, sorry for any confusion.
Old Feb 29, 2012 | 05:57 AM
psychoballistic
Not at the exact moment. I would like to try and sell each item in their entirety as I have them, but if nothing comes through, I will keep you in mind.
Old Mar 7, 2012 | 06:48 AM
psychoballistic
Bump
Old Mar 13, 2012 | 05:40 AM
psychoballistic
Bump. Reasonable offers will not be refused, need these gone.
Old Mar 13, 2012 | 11:14 AM
Sequence's Avatar
Sequence
approximate mileage on injectors?
Old Mar 13, 2012 | 06:44 PM
viperkiller7's Avatar
viperkiller7
will the utec work on my 08
Old Mar 14, 2012 | 11:09 AM
psychoballistic
Approximately 12,000 on injectors. Ran flawlessly for me. I needed bigger injectors for my upgraded setup.
Old Mar 14, 2012 | 11:14 AM
psychoballistic
I know for sure they work on 03-06 and I believe 07-08 as well.
Would like the Utec to go as one package since it is all wired up ready to be plugged in and go.
Old Mar 15, 2012 | 10:43 AM
psychoballistic
Price drop on injectors for $275
Old Mar 16, 2012 | 05:39 PM
Triji's Avatar
Triji
UTEC still available? Is it still in good working order? Can the boost controller be reversed as this would be going into a Super Charged G, not turbo.
Old Mar 17, 2012 | 04:56 PM
psychoballistic
Yes, the utc is still available. It's in perfect working order, had no problems with it, i had to upgrade because I needed bigger injectors and the Utec is good to about 750cc.
You wouldn't need to use the BC with a supercharger setup, your pulley size will dictate your max boost and you would have the ems tuned for your setup.
