Engine Intakes, Exhausts, Clutches, Turbos, etc...
Innovate MTX Gauges! Get 'em while they're hot
Old May 7, 2012 | 07:39 AM
S&R Performance's Avatar
S&R Performance
Vendor - Former Vendor
Default Innovate MTX Gauges! Get 'em while they're hot
We've got the latest and greatest by the guys at Innovate Motorsports. The new MTX gauges offer superior quality, accuracy and value. These gauges function as two in one so you don't have to spend extra money on other gauges or clutter up your interior. Here is more about them and links. As usual, let us know what questions you may have. We're here to work for you.
Innovate MTX Digital Water Temperature & Battery Gauge Kit Dual Function
The Innovate MTX Digital Water Temperature and Volt Gauge kit offers serves two functions in one gauge. This helps prevent your dash and interior from looking cluttered and also allows for additional monitoring for an aspect that you may not have meant to monitor before. You get accuracy, consistency and value in a great looking package.
Innovate MTX Series Boost-Vacuum / Shift Light Digital Gauge
The new MTX boost gauge and shift light does double duty for you. It works as an incredibly fast and accurate boost gauge and shift light so that you never miss a shift again. Innovate's sensors are some of the best in the business and each gauge comes complete with everything needed for a complete installation and two color face plates so you can better match it up to your interior.
KEY FEATURES
• Display as either inHG/PSI or BAR (seven-segment)
• Over Boost Warning (seven-segment)
• Progressive Shift Light or Single Stage Shift Light (outer LEDs)
Innovate MTX Series Oil Pressure and Oil Temperature Gauge
The MTX Oil Pressure and Temperature gauge allows for total management of your oiling system. You can precisely monitor your pressure and temp levels all in one.
Innovate MTX Digital Series Exhaust Gas Temperature (EGT) Gauge Kit
The new Innovate Motorsports MTX Digital Series Exhaust Gas Temperature (EGT) gauge is now available! This 2 1/16” (52mm) gauge features a water resistant casing, interchangeable faceplates and bezels, locking connectors for simplified installation, and MTS serial connections used to connect with other Innovate devices for logging to your PC, iPhone, iPod Touch, iPad, LM-2, DL-32, or ???
KEY FEATURES
• Change from EGT to CHT range. CHT range allows greater resolution
• Display in either degF or degC
• Change exterior LED as a fill bar or light a single indicating LED
• Program exterior LED ranges vs Color
• Program EGT Warning.
Innovate MTX-L Wide Band Kit
The Innovate Motorsports Digital MTX 52mm wideband is the best choice for accuracy and speed. The award-winning DirectDigital technology is faster and more accurate than common wideband gauges and is now more affordable! In addition, the gauge features a water resistant casing, interchangeable face plates and bezels, and 2 fully programmable linear analog outputs for use with aftermarket engine managements systems and dataloggers! Innovate set this one up so it can display lambda or air/fuel ratios for most common fuels, not just gasoline!
We will be running great deals on these all month long and if you order 3 of these at once we will even throw in FREE SHIPPING!
Old May 14, 2012 | 11:08 AM
S&R Performance
get em while they're fresh, everyone! Let us know what questions you have.
Old May 21, 2012 | 05:07 AM
S&R Performance
We've got killer deals on these gauges and if you order 3 or more, we'll throw in shipping. =)
Old May 21, 2012 | 08:23 PM
nizm350's Avatar
nizm350
I am still waiting on mine, but am not getting any response from anyone.
Old May 23, 2012 | 08:50 AM
S&R Performance
hey buddy, I'm assuming it's Keith. I've got 3 bounced back emails, no idea at all as to why. Just messaged you. =)
bcoffee20
Nov 19, 2015 06:39 PM
SharX59
Sep 30, 2015 10:54 AM
