Engine Intakes, Exhausts, Clutches, Turbos, etc...
Tomei V2 Headers and Test Pipes - Ready to ship!!!
Old Dec 27, 2012 | 03:05 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Default Tomei V2 Headers and Test Pipes - Ready to ship!!!
Looking to squeeze a little more power out of your car without making the jump to FI? Headers are certainly a must. As with all parts, go with a brand you trust. Tomei has been making race bred parts for years, and has had great success with their VQ35 program.
While there are only a handful of parts in their lineup, we are just going to focus on the Expreme headers and test pipes.
These were originally designed to fit the DE motor only but can be used on the HR motor, after re-configuring the exhaust manifold studs AND using DE test pipes or HFC's.
The 1st Version design had the targets of “Sharp throttle response”, “Sports engine enjoyment” & “True race exhaust sound”. The new version 2 design has all those target aspects met with the additional target of increased power gains. The designs were made and time painstakingly tested both on the engine bench Dyno in a controller environment and on the car in real life uses in the Z Masters race series in Japan. With these tests we found to have excelled in additional performance gains from the previous 1st Version model.
■THE EXPREME PERFORMANCE
RESPONSE: Instant throttle response which delivers a real race engine experience and feel.
TORQUE: Improved mid range torque. More torque gives your 3500cc engine more grunt and more fun.
POWER: More power in higher RPM range which makes a big difference between the factory settings and our EXPREME upgrade.
SOUND: The 1.5mm thin 304 stainless steel will deliver the harmonics of a dry racing sound. The feeling will exceed the famous Ferrari F355.
LIGHT WEIGHT: The super lightweight design flange and 1.5mm pipe were adopted for the optimum performance benefits. The end result was a reduction of 9.1kg. (When combined) the lighter weight will affect the cars handling with a lighter front end will make it easier whilst turning.
Along with the high quality headers, you will also receive; engine and outlet gaskets, all hardware, anti-seize, water pipe o-ring, heat shield, insulation and insulation tube, tie wraps, heater pipe gasket. So you will need nothing else for installation.
Retail pricing on the headers is $990, or $1320 when combined with their test pipes.
Of course, please PM me or use my contact info below for the special my350z forum pricing.
Old Jan 16, 2013 | 09:02 AM
Vivid Racing
Vivid Racing
Thanks for all the PM's! Still a few sets left!
Old Feb 7, 2013 | 08:24 PM
JDM_Cain's Avatar
JDM_Cain
PMed
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
gabe3d
Northern California
29
Jun 24, 2009 06:39 AM
nightcrawler_8
Mar 28, 2008 01:59 PM
se-r / gti-r
Feb 23, 2007 11:07 PM
JDMZ-33
Sep 7, 2006 11:41 AM
