(OEM) FS: '08 HR engine and trans
Old Jan 7, 2013 | 02:19 PM
billstein87's Avatar
billstein87
Default '08 HR engine and trans
SOLD
Hear it run. Make 280HP to the wheels all stock.
I want to sell this 2008 Base Model Z wrecked to someone who wants the engine with harness for a conversion. The engine and trans have 9500 highway miles and 12 months of racing ~25 hours of track time. The engine runs and has good compression. The Chassis is garbage unless you want a few parts on the right side that aren't terrible, but there's a lot of goodies left. I can deliver the car for a nominal fee. Maybe $0.40/mile?
Everything below is still on the car and is included in the price
  • engine , trans, harness, computer, Uprev/Forged Motorsport tune to 280+HP wheel, tuning cable and software
  • Abs motor, controller, master cyll, power booster
  • window net
  • racequip belts, cut (rebuildable)
  • 4 hubs
  • 3 corners suspension
  • 20 long lugs
  • SCCA t2 rear sway bar
  • fuel tank w 3 pumps and foam
  • stock headers
  • suspension large cam bolts in rear
  • goodridge braided brake lines
  • high flow downpipe, y, tail pipe (unknown damage)
  • 2 K&N filters
Right fender, door skin, and rear quarter are decent to undamaged.
free included I will give you the stock parts i still have like AC compressor and condenser, some interior parts, as well as brake rebuild kits, spare oil pan, and used spare hubs, master cyll, headers, throttle body, restrictor plates, axle parts, hoses, tie rod ends, restrictor plates, down pipes, y pipe.
If you buy this car, I will also make great deals to sell you the rest of the parts I have. Unfortunately I can't list them without pics, so you will have to PM me.
Thanks,
Bill
Attached Thumbnails '08 HR engine and trans-img-20130107-00029.jpg   '08 HR engine and trans-plantation-20130107-00031.jpg   '08 HR engine and trans-plantation-20121215-00012.jpg   '08 HR engine and trans-zfront.jpg
Old Jan 9, 2013 | 05:25 PM
billstein87
Price decreased.
Old Jan 9, 2013 | 09:09 PM
Marrocco350z's Avatar
Marrocco350z
Why was the plenum cracked? Was nitrous or force induction used on this car?
Old Jan 10, 2013 | 11:45 AM
billstein87
That's a good question. It's hard to see from the picture, but the impact at the front corner pulled the strut tower brace into the throttle bodyand cracked the inlet to the intake. The plenum isn't cracked structurally, just the inlet area is cracked.
Nitrous was not used. This motor is completely stock and has never been opened.
Old Jan 15, 2013 | 02:44 PM
billstein87
The Car is in South florida, zip 33325
Here are the other parts that could be packaged with the car sale at best internet price minus 20%:
quick release steering wheel
FIA racetech seat w mounts and cover
MXL Pista Data acq, O2 kit, GPS, splitter, etc
3 almost new bfg 285R18 tires
brembo brakes, carbotech pads
kw coilover kit
nismo diff (just rebuilt), rear, axles, driveshaft
diff cooler with hoses, filter, pump
safecraft fire system
8 Forgeline wheels, 4 10", 4-9", bent
8 Enkie rpf1 18x8.5, almost new
5 Volk Rays 350z Forged wheels
stillen long tube headers
underdrive lightweight front pulley, belt
front hub, new
2 front hubs, used
clutch master, new
clutch slave, new
clutch slave, used
10 long lugs, new
rear wheel speed sensors
brake rebuild kits, new
front speed sensors, new
rear hub, new
rear bearing, new
t2 springs
fuel pump, new
front sway, nismo
tie rod kit, new
titanium brake pad plates, new
throttle body, left, new
throttle body right, used
restrictor plates
2 sets front pads carbotech xp16, used
5-1/2 qts motul gear competition
2 qts gm syncromesh
misc hoses
tie rod ends
spare down pipes and y pipe
rear diff housing with wavetrac, almost new, with axle stubs and finned cover
power steering pump, new
spare headers, one welded
oil pan, new
motor mounts, used
oil pump, used
water pump, new
alternator, new
rear braided lines new
inner cv joint, new
abs module, new
tires, BFG, Hoosier, 285, 245, R, A
Old Jan 20, 2013 | 07:21 AM
midz350's Avatar
midz350
Price for just the engine?
Old Jan 20, 2013 | 08:04 AM
Mattysals's Avatar
Mattysals
Price for brakes?
Old Jan 30, 2013 | 06:55 PM
CKdevil's Avatar
CKdevil
Bill, PM sent.
Old Jan 30, 2013 | 06:58 PM
kno's Avatar
kno
interested on the brakes whats the price im local.
Old Feb 5, 2013 | 07:16 AM
billstein87
Hi all,
I just lowered the price, and added a price for motor/trans only
It now has an intake and turns over with good compression, but I haven't gotten the pump working yet. It shouldn't be long now.
Also I won't part out the car until the motor is sold.
Old Feb 10, 2013 | 01:54 PM
billstein87
Updated the post. It runs and still makes good compression!!
Old Feb 10, 2013 | 02:16 PM
KingBaby's Avatar
KingBaby
Hardest Setting
deals...
Old Feb 13, 2013 | 10:35 AM
Dude1312's Avatar
Dude1312
how much shipped 79407
Old Feb 13, 2013 | 05:09 PM
AndyBGAWTSuhZ's Avatar
AndyBGAWTSuhZ
How much for the Nismo Diff (what model diff is it btw and what lock-up % do you have on it??)
Shipped to 75056, Thanks!
Old Feb 13, 2013 | 06:40 PM
LB350z07's Avatar
LB350z07
dam glad your ok looks like you flipped the thing
Old Feb 13, 2013 | 08:49 PM
MyO3Z's Avatar
MyO3Z
What are you looking to get for 4 of the rpf1's?
Old Feb 14, 2013 | 05:40 AM
ehaalandtluk's Avatar
ehaalandtluk
Your inbox is full. I tried replying but I can't send you a message
Old Feb 15, 2013 | 04:59 PM
billstein87
Sorry inbox is now clean.
I have the rpf1s for sale in the wheels and tires section. Someone buy this dang motor so I can part out the car!
Old Feb 17, 2013 | 07:14 PM
xbeta92's Avatar
xbeta92
do you have the parts highlighted in the pic with all the hoses conecting them ?? if yes pm me price
Old Mar 12, 2013 | 04:58 PM
miLes.'s Avatar
miLes.
Pm sent
