FS: Haltech Sport 2000 w/ RacePak IQ3 **NEW**
Old May 7, 2013 | 08:19 PM
doyle4281's Avatar
doyle4281
Default Haltech Sport 2000 w/ long flying lead harness **NEW**
This is a brand new in the box Haltech Sport 2000 stand alone management system with "long flying lead harness". This is a universal system that can, and has been used on practically any powerplant available. It is an extremely user friendly system, and is surprisingly straight forward to install, and operate. Essentially, the "long flying lead harness" comes with unterminated ends which you cut to length and connect to sensors/injectors/coils/esc on your engine. The other end of the harness is a fuse/relay box, which only requires a few power and ground connections from the battery. The ECU plugs into the harness, which is equipped with an on board MAP senor(2bar). The greatest advantage to the Haltech system, aside from its simplicity, is its ability to interface with the RacePak digital dash with one plug. This allows you to display any parameter from the ECU on to your dash, eliminating the need for sensors, senders, and gauges. This can equate to quite a bit in savings, and an exponential gain in engine monitoring. The RacePak is also sold with on-board data logging, for those using it for track use. Haltech has customer service second to none, and their techs will guide you through your specific installation, step by step. Again, this system is brand new, and sell for $2200 on the low end.
$1800
Manufacture information
Platinum Sport 2000 | Haltech - Engine Management Systems
Wiring Diagram
http://www.haltech.com/wp-content/up...iagramrevJ.pdf
Old May 10, 2013 | 07:11 PM
doyle4281's Avatar
doyle4281
RacePak IQ3------SOLD
Haltech air temp sensor--------SOLD
Haltech coolant temp sensor---------SOLD
Haltech Boost Control solenoid-------SOLD
Haltech Wideband O2-----------SOLD
Haltech Sport 2000 w/ long flying lead harness--$1850
For anyone interested in this stand alone engine management system, I wanted to share some installation information, to show how user friendly, and how much support Haltech provides. These systems are powering some of the most powerful cars around, and are a breeze to install. This is great for an LS, SR, RB, VH45, esc swap. Thanks
Old May 18, 2013 | 04:03 PM
doyle4281's Avatar
doyle4281
thread updated with items still available.
Old May 28, 2013 | 08:45 PM
doyle4281's Avatar
doyle4281
Haltech Sport 2000 with harness is still available
chad_everson
Mar 30, 2013 10:18 PM
Dynosty
Nov 21, 2008 04:45 AM
