FS: Built bottom end Long Block
I have a built bottom end long block for Sale. I built it last winter at a shop in Akron, Ohio called Pro Car Associates. It has 5000 miles on it and the only reason I am selling is because i parted my car. The block was broken in on at the shops engine dyno and for the first 2k miles the block did not see more than 8 psi. The other 3k the block saw 12psi. The block was completely broken down inspected and cleaned. If something needed replaced it was with either oem parts or aftermarket. There is zero issues with the block but you will need injectors because i sold the current ones with my momentum kit. If you have any questions please text me at 330-322-1414 and I am asking 4k obo plus shipping and fees.
Supertech pistons 8:8:1
Supertech piston rings
Manley h beam rods
Clevite rod bearins
Cosmetic Ds gasket
Cosmetic Ps gasket
Oem master gasket set
up rev Oil pump
mishimoto thermostat
Arp head studs
Arp main studs
bored .02, machined and honed
Manley h beam rods
Clevite rod bearins
Cosmetic Ds gasket
Cosmetic Ps gasket
up rev Oil pump
Arp head studs
Arp main studs
Whats fishy about me selling my engine when i parted my entire Z? theres nothing wrong with it at all and there is no reason for you to start speculation with my thread for no reason.
Tochigi_236
Sep 27, 2015 03:40 PM
