FS: JWT S2 Cams
Old Sep 8, 2016 | 06:16 PM
craig12895's Avatar
craig12895
Default JWT S2 Cams
Bought these heads from a guy with a built g35. I plan to switch to different cams so these are for sale.
They are JWT S2 cams. They retail for $1200 https://www.z1motorsports.com/engine...ms-p-2138.html
They have less than 3k miles on them and were inspected by a performance shop after being removed from the g35 to ensure everything was still good (That is why all of the bolts are loose, they were removed in order to be inspected).
Im looking to get $700 for them.
Old Sep 8, 2016 | 06:25 PM
jhc's Avatar
jhc
General & Tech Moderator
Nice ad, Craig. glws!
Old Sep 10, 2016 | 11:55 AM
craig12895's Avatar
craig12895
Here are the specs pulled directly from Z1's website for anybody interested.
JWT S2 Cam Specs
256 DEG DUR. / .430"(10.92MM) LIFT, INT. ADVANCED 2 DEGREES. ** NOTE: CAM UPGRADES MAY REQUIRE THE IDLE RPM BE SET TO 850 RPM TO PREVENT POSSIBLE STALLING AT IDLE. S2 CAMS ARE DESIGNED TO DELIVER SIMILAR POWER TO JWT S1 CAMS, BUT WITH MORE IDLE STABILITY. WILL NOT WORK ON 2005+ REV-UP ENGINE WITH EXH. CAM CONTROL.
Old Sep 13, 2016 | 01:27 PM
craig12895's Avatar
craig12895
bump
