anywhere to ground a light in the driver's footwell area?
Old Dec 27, 2004 | 07:06 AM
rummya87's Avatar
rummya87
Default anywhere to ground a light in the driver's footwell area?
i've been searching the forums and i cant find an answer.
i ran a 10 gauge wire from the battery to a fuse box i installed under the passenger side dash. from this fuse box i installed a 12 gauge wire that runs behind the center console to the driver's side and it hooks to a switch which has the 12v end of the wire hooked to it ... i need to know where to ground the grounding end wire somewhere in the driver's footwell area.
i was hoping to test out the circuit for a second without a ground to see if it would turn on but when i flip the switch ... no go. anyways
Uriyo_
Sep 8, 2021 08:46 AM
D_Rod
Sep 29, 2015 04:42 AM
samansharif
Sep 25, 2015 12:31 PM
