How to install rear driver side reverse light?
Old Feb 1, 2005 | 06:50 AM
lymonke's Avatar
lymonke
Default How to install rear driver side reverse light?
Do I need to remove the whole back bumper in order to install the rear reverse light?
Thanks
Old Feb 1, 2005 | 09:19 AM
chattermark's Avatar
chattermark
Do you want to change the bulb or the cover of the reverse light. If you only want to change the bulb, then open your trunk, look at the brake lights. Poop of the covers on the light. (little black round things) Unscrew the screws, (3 I think) and pull the tail light out kinda up staright out. Disconnect the lights, and look down in the hole that is there. You can take them out with your hand, it is a little tight, but it can be done. I did it. Hope this helps <M>
Old Feb 1, 2005 | 12:24 PM
lymonke's Avatar
lymonke
Default Re: How to install rear driver side reverse light?
I want to change the cover of the reverse light ( the bottom in white not the brake light).
Old Feb 1, 2005 | 11:32 PM
lymonke's Avatar
lymonke
Default Re: Re: How to install rear driver side reverse light?
a lil' help anyone
Old Feb 2, 2005 | 02:41 PM
Faluzure's Avatar
Faluzure
That helped me tons! I ordered replacements.
Bookmarked!
Siqcology
Sep 18, 2019 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
Suffolk350z
Sep 13, 2015 02:43 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
