Harness mount positions
Old Feb 8, 2005 | 07:18 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
Default Harness mount positions
Hey guys,
i just installed my new Bride Brix seats and i got retractable harnesses to go with the seats and i was wondering for those of you with harnesses, where did you mount the points for the shoulder straps? the lap belts are an easy mount, but i need some ideas for the shoulders....any input would be great!
Old Feb 8, 2005 | 07:19 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
whoops, accidently posted twice.....sorry...
Old Feb 8, 2005 | 07:41 PM
EnthuZ's Avatar
EnthuZ
Not sure what "retractable harnesses" are, but may I recommend a BCR harness bar?
Victor still won't allow attaching pix..........so check out www.BCRLtd.net
Old Feb 8, 2005 | 07:45 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
retractable harnesses allow you to still move around like a normal seat belt, and lock up like a normal belt when it needs to
Old Feb 14, 2005 | 09:13 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
on my car, i have the takata harness. I wrapped the rear harness straps around the rear strut bar. This should be ok since that's a solid point, and you should be able to use that as if it were a harness bar. or you can drill holes in the back somewhere, and bolt them in.
never bolt the shoulder straps down to the floor behind you, unless you use a harness bar, because if you do that, in a bad wreck, it will compress your spine.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
