Tein Hood Damper Picts.
Old May 11, 2005 | 07:20 PM
kevinapex's Avatar
kevinapex
Default Tein Hood Damper Picts.
No more hood post! Don't know why Nissan doesn't put these on from the factory?
All the time I spend under the hood, working around the rod/ hood prop, I thought these were a good idea. Work great for stock hood, small cuts made in right and left resin covers so pistons sit recessed. Paid around 115.00
Attached Thumbnails Tein Hood Damper Picts.-nissan-picts.-045.jpg   Tein Hood Damper Picts.-nissan-picts.-044.jpg   Tein Hood Damper Picts.-nissan-picts.-042.jpg   Tein Hood Damper Picts.-nissan-picts.-043.jpg
Old May 12, 2005 | 04:51 AM
manofsteele2003's Avatar
manofsteele2003
The reason Nissan didn't put those on from the factory is because they wanted customers to feel how light is hood is.
Old May 12, 2005 | 05:47 AM
Zivman's Avatar
Zivman
Do the dampers open the hood up more or less than with the stock hood prop?
Old May 12, 2005 | 06:39 AM
Moodie's Avatar
Moodie
Minivan Racer
I thought you had to remove the covers (battery and fluid) after hood dampers install for it to close properly???
Old May 12, 2005 | 10:35 AM
Z CRUZN's Avatar
Z CRUZN
Please post a close-up pic where you had to cut up the plastic around the batt/brak covers. Thanks!
Old May 12, 2005 | 04:48 PM
kevinapex's Avatar
kevinapex
Default Tein hood info
The hood opens about the same 38" from bumper to hood lip.
Hood closes great with the resin cover cut to fit pistons.
Here are some picts. of cover mods.
Attached Thumbnails Tein Hood Damper Picts.-nissan-picts.-046.jpg   Tein Hood Damper Picts.-nissan-picts.-047.jpg   Tein Hood Damper Picts.-nissan-picts.-048.jpg
Old May 12, 2005 | 05:11 PM
doodeitstom's Avatar
doodeitstom
Ok, so with those you can't let the hood close on its own. However, isn't it bad to press down on aluminum hoods?
Old May 12, 2005 | 05:20 PM
kevinapex's Avatar
kevinapex
It still closes on it's own, soon as pistons let off, drop, (about 8"-10") then BLAM! it shuts!! YA.
Old May 12, 2005 | 05:43 PM
doodeitstom
oh damn, peace, I am going to get a set
Old May 14, 2005 | 10:52 AM
Armitage's Avatar
Armitage
Damn. Those cutouts are slick. Nice work.
Old May 14, 2005 | 03:47 PM
kevinapex's Avatar
kevinapex
These are so nice, hood stayed open durning all my dyno runs also.
If you plan on spending any time under the hood, I think these are a must have for less than 130.00!!
Old May 17, 2005 | 03:35 PM
richc86's Avatar
richc86
I have them on mine, but I did not modify it...so yes the side of the hood sticks up higher than the fenders & it looks kinda f***** up. Good looking piece of work. What did you use for the cut out??
Old May 17, 2005 | 03:42 PM
BostonZ's Avatar
BostonZ
nicely done!
Old May 17, 2005 | 03:57 PM
subdriver's Avatar
subdriver
They are great, I just don't like the colour.
Old May 17, 2005 | 06:47 PM
kevinapex's Avatar
kevinapex
I did cut outs with razor blade, cleaned them up with fine tooth file.
Teins GREEN, That color costs $$
Old May 17, 2005 | 09:47 PM
ReavTek's Avatar
ReavTek
Wow, with a razor blade? Did it require alot of sawing? Any tips or suggestions?
Old May 17, 2005 | 11:47 PM
BOMEX180's Avatar
BOMEX180
I wish they make those for my 180sx
Old May 18, 2005 | 01:18 AM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
I am back and forth on these...More important things ro spend money on for now but they are cool.
Old May 18, 2005 | 03:03 AM
Z BOY's Avatar
Z BOY
very nicely done! props for your ingenuity!
Old May 18, 2005 | 07:37 PM
kevinapex's Avatar
kevinapex
The cuts are real easy if you take your time, I took a piece of steel chalk, put a point on it. Close the hood as far as you can, and still get your hand in, with the chalk trace around the pistons, marking on the resin covers.
Remove the covers from car. Get a steel straight edge, new razor blade and start cuts using edge to stay just outside chalk marks, just enough to scribe the plastic cover. Keep making cuts until you break through. clean up cuts with fine tooth file. Take your time, and for Gods sake don't drink before doing this!!!
