removing the original wing
Old May 14, 2005 | 11:47 AM
mono11's Avatar
mono11
Default removing the original wing
hey guyz i need to remove the original wing cause i wann install a nismo wing, i only see 2 screws holding it, and some ahisive i think can anyone give me some pointers before doing it my self i allready tried it and i very **** cause i dent it my hatch a lil when i tried.. please help
Old May 15, 2005 | 06:08 AM
kardan350z's Avatar
kardan350z
Default "Stock Rear Aero Spoiler" Removal
It's not easy to remove. There is Automotive Dbl. adhesive tape around the entire perimeter of the spoiler. Yes there are (2) actual bolt connections, but there is also two "snap-in" plastic connectors on the rear edge abuot 16" apart of center.
I removed mine on a warm day to help the tape release. It took (3) guys at times to pull it up. Just try to get an edge up, and slowly keep pulling straight up. It may help to spray some lighter fluid on the tape edge, once you can see it a little under neath. It took 20 minutes of pulling and working at it to get mine off. That was after an hour of fooling around just to get it to come up a little. Be prepared to spend time cleaning where to tape was.
Have patience.....and good luck.
Old May 15, 2005 | 12:08 PM
Christopher's Avatar
Christopher
get fishing string and slowly but surely , work it back and forth under the spoiler. Kind of like flossing your teeth, but its flossing your spoiler. It take some patience...
Old Jun 11, 2005 | 11:15 PM
jinsei888's Avatar
jinsei888
use fishing string and a blow drier...and patience
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
nanotech
Oct 2, 2015 05:02 AM
Depravity
Oct 1, 2015 04:49 PM
