Lambo Doors?
Old Oct 17, 2005 | 02:53 PM
DJMC126's Avatar
DJMC126
Default Lambo Doors?
Ok, so one of the small mods i am going to be doing is Lambo Doors. I need to know a QUALITY kit, I see on e-bay they have ones from $1899.99 to $415.00. I am sure it is, you get what you pay for. Just curious what you guys suggest?
Thanks,
Ryan
Old Oct 17, 2005 | 03:07 PM
Vamos_Rafael's Avatar
Vamos_Rafael
well...
the more expensive one is more quality than the cheaper one...
thats rule of society and rule of economy...
Old Oct 17, 2005 | 03:26 PM
DJMC126's Avatar
DJMC126
Yeah thats what i figured, I have a friend at Autoloc with the automatic lambo doors, but he says you have to tap into the security system and bypass a whole bunch of crap!
Old Oct 18, 2005 | 11:49 AM
VertexFightR's Avatar
VertexFightR
I've installed almost every kind of kit, from the $400 eBay kit, to $2000 LSD kits. As a rule of thumb, the more expensive kits are better quality.
Here is my opinion of quality and use over the kits:
#1 LSD: This kit has the highest quality materials and fits excellent. It goes up about 50 or 60 degrees.
Tied #2 VDC/GTFactory: The Vertical doors kit and GTF kits both run about $1000 for a 350z. However, the GTF kits REQUIRES the use of their fiberglass door panels, which are additional. The LSD kit installs relatively well (must modify certain things in order for best performance) and goes up about 50 degrees. The GTF kit install is the most difficult out of all existing kits for the 350z in particular. It uses the same high quality components as the LSD, but is a full custom weld on unit that requires some 50 - 75 hours for precise installation. It goes up almost 90 degrees, which is the standout feature of this kit.
Everything else is pretty much crap, including Decah and everything from eBay. The Decah kit's shock mount goes bad very quickly, as well their shocks seem to be the weakest. The eBay kits just don't fit without MAJOR modification, and with the additional work, ends up costing the same as the VDC.
Old Oct 19, 2005 | 04:52 PM
zrausch's Avatar
zrausch
i like the GTF kit cuz it goes straight up and not to the side.
http://www.aerokits.net/DiabloHinge/gtf.htm
Old Oct 19, 2005 | 06:23 PM
mikebranson's Avatar
mikebranson
Those are nice, but as previously stated, will require the fiberglass panels which give it the clearance necessary to go "vertical"
Mikey R6
Sep 19, 2015 01:48 AM
T'S 350Z
Event Photos
13
Sep 17, 2015 12:55 AM
roadmax
Sep 12, 2015 05:55 PM
AP350z223
Sep 8, 2015 04:38 PM
