are there any body kits that actually improve aerodynamics?
Old Oct 19, 2005 | 09:46 AM
EdgeOfSanity's Avatar
EdgeOfSanity
Default are there any body kits that actually improve aerodynamics?
instead of ruining the good lines of the z? Every body kit i see just looks like some tacky ricer kit made to draw attention. There are a few exceptions but do any of them actually improve the aerodynamics of the car?
Old Oct 19, 2005 | 09:47 AM
Fletch69z's Avatar
Fletch69z
I"m sure there are some. But I'll defer to those with more knowledge. Bump.
Old Oct 19, 2005 | 09:55 AM
mavtais's Avatar
mavtais
The only body kit parts that actually function are the front air dam and the rear wing, so long as you mount them properly (does not flap in the wind). Don't know which one works best for you, depends on your driving style and what function exactly you want.
Old Oct 19, 2005 | 10:17 AM
Rampage's Avatar
Rampage
The Nismo versions supposedly decreases drag and lift while adding downforce. I have seen no solid numbers to back that up though. Most the kits do nothing but add drag and weight to the cars. In most cases, only the front lip spoiler provides much benefit and that is only for high speed or highway driving.
Old Oct 19, 2005 | 11:00 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
C-west conducts wind tunnel tests on all of their kits.
Old Oct 19, 2005 | 11:59 AM
homiusang's Avatar
homiusang
Veilside from what I heard. But I have no data to back this up either.
Bump for more info.
Old Oct 19, 2005 | 12:18 PM
mdracer76's Avatar
mdracer76
ING's, TopSecret,and C-west all wind tunnel test thier peices. As well as wind tunnel testing.. there are several racing series in japan (besides JGTC) that show proven benifits to some of the lap times between a stock bodied car and one that has the right Aero-Tuning parts. Its also VERY un-usual to see parts from one manufacture mixed with another.. as these kits work as a system.
My kit felt lighter/if not the same weight as the poly OEM bumpers it replaced. I did not put them on a scale
Old Oct 19, 2005 | 12:35 PM
BamBam's Avatar
BamBam
Adding to what Mike said. From what I have read, the JDM kits are designed with aerodynamics in mind and styling as a benefit. There appears to be some question as to why we 'Mix -n- Match" our body kits when they have been designed as a unit to provide both form and functionality from the Japanese. We tend to think in regards to look, they are focused on performance.
As Mike stated there are proved time trials for some of these kits showing how much they can shave off your lap times. But I am not sure where you can find this information.
I also think some side skirts would be beneficial for cooling the brakes if install and vented properly.
Old Oct 19, 2005 | 12:45 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
http://www.c-westusa.com/labs/index.asp
Old Oct 20, 2005 | 07:59 AM
Resolute's Avatar
Resolute
I think the Ings Nspec side skirts would work to increase downforce on a very low car. and FYI, there is no way to reduce drag and increase downforce, aerodynamic downforce requires drag.
Will
Old Oct 20, 2005 | 08:31 AM
VenomZ's Avatar
VenomZ
Esprit does wind tunnel testing as well
Old Oct 20, 2005 | 09:21 AM
spdu4ia's Avatar
spdu4ia
you sure about that... i've never heard of Esprit doing any windtunnel or aero testing (but i could be wrong)...
i know C-west / Top Secret do for sure.
Old Oct 20, 2005 | 10:14 AM
tmounk's Avatar
tmounk
As long as it doesn't slow your car down, who cares, it looks better and different from most.
Old Oct 20, 2005 | 11:58 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
For those that track, anything that can help improve your driving experience is worth it
Old Oct 20, 2005 | 02:51 PM
EdgeOfSanity
i care, i've never seen the point of non functional mods outside of a nice set of wheels.
Old Oct 20, 2005 | 04:52 PM
05-Z's Avatar
05-Z
downforce mod kit, solid and performing with the best.
Old Oct 20, 2005 | 05:09 PM
Resolute's Avatar
Resolute
Who makes that kit? Will it mount on the back of a Z?
Lord, I'm joking. LMAO, that's the craziest thing I've ever seen.
Will
Old Oct 21, 2005 | 11:55 AM
BamBam's Avatar
BamBam
Looks like the Jeepneys in the Philippines.... WAY COOL..... you want to get noticed right? This is a definate way to make sure everyone sees you coming and going....
Old Oct 21, 2005 | 11:58 AM
D350Z10's Avatar
D350Z10
Off course.. The veliside ver 3, top secret, do-luck are all very aerodynamic kits.
Old Oct 21, 2005 | 06:06 PM
nickintempe's Avatar
nickintempe
Not possible. Aerodynamically-generated downforce is a form of drag. The only reason that any race car (whether it be F1, NASCAR, NHRA, etc.) has a wing is that the slight loss of straight line speed is still preferable in terms of both safety and lap times to the loss of traction.
