Headlight adjustment for 06's?
Old Nov 7, 2005 | 08:37 PM
Gryphin's Avatar
Gryphin
Default Headlight adjustment for 06's?
I looked where the gear was for the 03-05's and i didnt see that gear... does anyone know where they might have put it?
Old Nov 7, 2005 | 09:57 PM
Gryphin's Avatar
Gryphin
bump
Old Nov 8, 2005 | 10:17 AM
barthelb's Avatar
barthelb
Master
I couldn't find it on my 03, do you have to remove something? I thought it was right behind the light.
Old Nov 8, 2005 | 10:19 AM
Gryphin's Avatar
Gryphin
on the 03 you just look straight down when you are looking from top of the headlight.... you might need a flashlight, but its down there... but i think they moved it for the 06's
Old Nov 9, 2005 | 08:07 AM
Gryphin's Avatar
Gryphin
bump... guess ill have to rip apart my front bumper and look.... just thought someone might know
Old Nov 9, 2005 | 04:58 PM
TruBluZ's Avatar
TruBluZ
Rip it up fool! You don't need to adjust them!
Old Nov 9, 2005 | 06:19 PM
Gryphin's Avatar
Gryphin
lmao, ok me you tomorrow! lmao j/p
Old Nov 9, 2005 | 06:24 PM
Mr_Drifter's Avatar
Mr_Drifter
So the 06's still have the same problems as previous years with the headlights aimed to low from the factory?
Old Nov 9, 2005 | 06:39 PM
TruBluZ's Avatar
TruBluZ
I think he wants to change something...it doesn't need this
Old Nov 9, 2005 | 06:52 PM
Gryphin's Avatar
Gryphin
nah nothing is wrong with then i just want to play with it a little
Old Nov 11, 2005 | 02:25 AM
ricks350z's Avatar
ricks350z
I like the new 06 headlights. I see a big difference at night time. It seems very bright. The angle of th beam seems very wide. The highbeam is very bright--so bright, it will blind the person in front of you.
Old Nov 13, 2005 | 09:53 AM
KrimZen's Avatar
KrimZen
acually, my left light seems to be aimed a tad bit lower then the right... is there no fixing that?
Old Nov 13, 2005 | 02:19 PM
Gryphin's Avatar
Gryphin
^^^ thats what i wanted to toy with... but i think i found the bolt you turn i just havnt poped off the cover for it.. to check and see
Old Nov 13, 2005 | 02:41 PM
hbenet's Avatar
hbenet
The adjustment for the 06 lights is the same as the 03-05.
I had to adjust the 06 lights after the swap.
Just use the same instructions found on several posts on this forum.
Good luck.
Old Nov 13, 2005 | 03:49 PM
Gryphin's Avatar
Gryphin
werid, because ive done the adjustment on the 03 and 04 , but i dont see it on my 06'
Old Nov 16, 2005 | 01:04 PM
Gryphin's Avatar
Gryphin
ok i found it after looking for a while.. its right infront of your face... well comapred to the other models... My gears have a CAP over them.. you pop off the cap and adjust the beam with a + head screwdriver..
Old Dec 28, 2005 | 01:32 PM
Gryphin's Avatar
Gryphin
passenger side is too low, if you find a flat wall next to level ground, follow the same steps as adjusting the 03-05 headlights...Get the car on a flat surface 8' from the wall and the hot-spot should be at 26.5'' this will put it just high enough to cover the entire road, and curb, but not blind oncoming drivers... stock mine was around 24 on the driver and 23 on the passenger side
Old Dec 28, 2005 | 01:33 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Originally Posted by mc350z
i just got my 06 lights.
is my driver side too low or is the passnger too high?
I put my 06 headlights on last week and the beam looks the same as yours. I didnt think anything of it.
