removing the center console now. HELP NEEDED!
Old Nov 25, 2005 | 06:36 AM
KTaylor's Avatar
KTaylor
Default removing the center console now. HELP NEEDED!
I did some searching this morning and founs some old useful threads but they did not help me out enough and the step through guide that use to be on here doesnt come up when you click on its link so... right now i have removed the lower peice of the console as you can see from the first pic. In the second pic i removed the 2 screws near the thermostat stuff that are in the front when you remove the lower piece. in the third picture i removed the 2 screws under the rubber mat in the nav compartment. this is where i am stcuk what do i do now? in the last pic there is one screw on each side that you can see once you remove the screws under the nav compartment rubber piece. do i take those out? whats the next step and am i doin this right so far? Thanks for any help or suggestions cause im working on this now and quick replys would be awesome!
Thanks alot. Kurt
Attached Thumbnails removing the center console now. HELP NEEDED!-screw.jpg   removing the center console now. HELP NEEDED!-screw-1.jpg   removing the center console now. HELP NEEDED!-screw-2.jpg   removing the center console now. HELP NEEDED!-screw-3.jpg
Old Nov 25, 2005 | 07:15 AM
KTaylor's Avatar
KTaylor
anyone???
Old Nov 25, 2005 | 07:16 AM
ZlleH's Avatar
ZlleH
http://liljerk.morpheus.net/350Z/dash_removal/
Old Nov 25, 2005 | 07:26 AM
KTaylor's Avatar
KTaylor
thank u very much!
Extreme Dimensions
Body Exterior
Nov 9, 2015 10:47 AM
