you need to put a little heat on the bolsters and see if you can get those wrinkles out, or it will wear alot faster, cause i know its cold there. you'll have to remove a few hog rings but the tighter the better. looks good though
thanks for the info, what do you mean by removing a few hogrings? and what exactly is the bolster? I understand that I need to put some heat on it but why would I have to remove hogrings to do that?
