instructions on changing the clear front corners
Old Apr 28, 2006 | 06:35 PM
Changvi's Avatar
Changvi
Default instructions on changing the clear front corners
I just received JDM clear corners today. As i read the instructions, the diagram showed that the inner fender guards need to be removed in order to access the two screws that hold the lense in place. Is there an easier way to access and change the clear bumper lights? Any inputs would be appreciated. Thanks..
Old Apr 28, 2006 | 06:54 PM
fairladyinit's Avatar
fairladyinit
I changed my corners in like 30 mins. Just remove the under panel and you should be able to reach the two screws to remove the stock corners. Also a short screwdriver makes it very easy, because the windsheild wiper fluid gets in the way. Shouldn't be too hard. You may also need a friend to pull the bumper back a bit for you to reach the screws holding the corners.
-Mike
RiujinZero
Sep 25, 2015 01:19 PM
Bigsyke
Sep 11, 2015 06:19 PM
