Whos installed a aftermarket steering wheel?
Old Jun 14, 2006 | 03:57 PM
G352NV's Avatar
G352NV
Default Whos installed a aftermarket steering wheel?
Ill be installing one in the next few days. Any tips?
Old Jun 14, 2006 | 06:10 PM
roncfpz's Avatar
roncfpz
Did mine. Make sure you get the correct airbag sensor resistors. The one that came with my MOMO wheel did not work. I contacted www.airbagonoff.com and purchased the correct kit (package of 2). Also, make sure you do not strip the mounting bolt. I forgot the correct torque specs. Last tricky step is the wiring for the horn (if your new one allows). Here is a good thread with pictures that helped explain process of removing stock wheel, air bag, etc.
https://my350z.com/forum/body-interior-exterior-and-lighting-diy/77855-diy-for-steering-wheel-removal-and-steering-wheel-audio-control-unit-install.html
Good luck!
Ron
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
SharX59
Sep 27, 2015 09:23 AM
