Tint problem help
Just got my Z tinted on 2/20 and am having trouble with alot of distortion out rear window at night. Headlights are mirrored up and down entire window along the defroster lines. Installer said was probably still wet and would dry out but it has been 4 days and still bad. Anyone else have this problem? Thanks
did tint work few years back just do it on my cars now.
if its cold out like anything less then say like 70 deg. and no direct sunlight on car windows could take some time to dry so he isnt lying to you just give it a chance if not bring it back and make him redo if the place is reputable you should have no problem just say you are dissatisfied and want it replaced.
we did it all the time if some one rolled down there window as soon as they left garage.
but this isnt the case just be patient.
it will all be good
it will all be good
Thanks for the info
I have never had any tinting done before and I was nervous but it has been very cold here so I will be patient and run the heat more!
I also have some bubbles up around the top and he said that should go away too but I wonder if it is because these windows reseal every time you close the door?
