Door won't open
Old Sep 21, 2006 | 02:27 PM
Uncle Jr's Avatar
Uncle Jr
Default Door won't open
Has anyone had an issue with their (driver's side) door not opening, from both inside and outside. the lock itself seems to be working, the power window works, but it's stuck closed. I've had this car for one week exactly, it's an '03 touring with 31k miles. now i have to climb across the passenger seat until it's fixed, ridiculous looking.
any idears?
Old Sep 21, 2006 | 03:19 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
was the car in a previous wreck that may have tweaked the frame? have you done a carfax on it?
You may need to try brut force to get the door open, then ispect for damage and find whats holding it shut. Unlock it, roll the window down and make sure the door can swing full open and try using your legs to push it open. Sounds crazy (becuase it is) but its necesary. Be sure to check the hinges when you get it open. Maybe some wd-40 on it?
gl, pics if you have a chance.
Old Sep 21, 2006 | 04:21 PM
350zz053's Avatar
350zz053
Yea i had that happen...like it was stuck between lock and unlock...i forgot how i did it. But it only happens when i hit he buttons in some wierd sequence...
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
