5at shift knobs?
Old Dec 20, 2006 | 01:28 AM
Zebrick's Avatar
Zebrick
Who started the fad of putting boots on 5at? Does the dealer give you hard time when you take your car in for service?
Old Dec 20, 2006 | 04:04 AM
PythonLaX's Avatar
PythonLaX
Dealer hasn't given me a hard time. They never even mentioned it.
Old Dec 20, 2006 | 04:06 AM
nothingremains's Avatar
nothingremains
what one is this??
Old Dec 20, 2006 | 06:54 AM
PythonLaX's Avatar
PythonLaX
Originally Posted by nothingremains
what one is this??
That is the all aluminum RAZO **** model RA89.
http://cgi.ebay.com/ebaymotors/RAZO-...QQcmdZViewItem
Old Dec 20, 2006 | 09:19 AM
nothingremains
does it get hot? im Florida in the summer could be painful..
Old Dec 20, 2006 | 10:02 AM
z-u-later's Avatar
z-u-later
Yeah, I can just see the service technician trying to find 1st gear and grinding your transmission. Or worse yet, trying to find 1st gear and puts it in reverse instead & accelerates backwards into another car or the wall . . .
Old Dec 20, 2006 | 10:04 AM
m0nkie's Avatar
m0nkie
new rear bumper thanks to dealer??
but ya, I think the technicians get it when they find no clutch..
Old Dec 20, 2006 | 12:49 PM
PythonLaX's Avatar
PythonLaX
I have the aluminum/carbon fiber shift **** and the aluminum does get quite hot in the summer and of course its pretty cold in the winter but you don't have to worry about that in sunny florida
Old Dec 20, 2006 | 01:33 PM
JMT's Avatar
JMT
Are the aftermarket shift ***** difficult to install given the lock button?
Old Dec 20, 2006 | 02:00 PM
PythonLaX's Avatar
PythonLaX
It is really easy to remove the stock 5AT ****. There is only one clip holding it on then it slides right off. Here is a good link showing how to do it:
https://my350z.com/forum/showthread....ight=momo+****
Old Dec 20, 2006 | 04:32 PM
MrKaira's Avatar
MrKaira
Really MrZ31
that is what I was gonna say
Old Jan 16, 2007 | 09:38 AM
PimpinMyBlackZ's Avatar
PimpinMyBlackZ
Does anyone know of any good shift boots and shift ***** for the automatic 06's b/c i called momo and they said that theres would not work on my car b/c the button on the shifter is in the front. So i dont know of any boots and ***** i can get for my car. Any Ideas?
Old Jan 16, 2007 | 11:09 AM
PythonLaX's Avatar
PythonLaX
The Momo **** will work, not sure why they told you that. When you take off the stock ****, there is just a rod that you push straight down which is exactly how the momo **** works. I have an 06 with a RAZO shift **** and it works great. As for the shift boot, I bought one at Pep Boys and cut it to fit around the aluminum ring around the shifter. Works great.
Old Jan 16, 2007 | 11:17 AM
jcpeyton's Avatar
jcpeyton
subscribing
Old Jan 16, 2007 | 07:22 PM
nothingremains
Originally Posted by jcpeyton
subscribing
point?
Old Jan 16, 2007 | 07:51 PM
Roger V's Avatar
Roger V
Is there a way to make the razo sit lower?
Old Jan 17, 2007 | 09:52 AM
MrKaira's Avatar
MrKaira
Really MrZ31
might be possible if you take off the plastic rod that sits on top of the metal one. that's what I did and it made the momo **** i have sit about an inch-inch&1/2 lower. Don't know how the razo installs tho.
Old Jan 17, 2007 | 12:26 PM
  #38
Roger V's Avatar
Roger V
I like how the Razo doesn't have the push button on the top.
Old Jan 17, 2007 | 12:44 PM
  #39
bonusfrag's Avatar
bonusfrag
I did the 5AT shift ****/boot mod as my first Z modification, and I did a poor **** job on it. i warped the trim ring, got a little too happy w/ the dremel and chopped too much plastic off of it. And I think I damaged the gear display thingie a bit (the black plastic piece w/ gear labels that sits under the ring)...
Is there a reason I can't just buy the manual version of the center console piece? (the finish plate I think it's called)
Mrpratt help me out on this, or anyone
Old Jan 17, 2007 | 01:46 PM
  #40
z-u-later's Avatar
z-u-later
I think this will be my next mod on my '06. Where did you get the RAZO shift ****? On the shift boot, is there a specific one at Pep Boys that you got?
