Just wanted to see what everyone thinks. All I used was 2 1.5" 90 degree brackets, drilled a hole for each in the grill and bolted them down. The ones in the picture are only 1 inch, not the actual ones I used. I forgot to take a picture of the actual ones before I put the plate on. It works perfectly without touching any of the painted areas, very close though.
I had to drill at a 45 degree angle but it staightened out when I bolted on the brackets. It was kind of a pain. Also I am pretty sure it will hold up at least it did at 125.
