Grille to put on when stock grill has been cut out?
So I regret cutting my stock grille to see the IC because now the IC scares pretty much everybody away. Since I cut out the stock grille, I was wondering if anybody else has done that before and found a aftermarket grille that can still be installed when the whole stock grille has been physically removed.
I'd basically need something that could be installed with it being supported on the outer edges instead of being supported by the stock grille. Or does anybody have any ideas how I could get this going?
Only thing I can think of his having some plastic work done to melt a grille in or something.... But I have pretty much zero knowledge of body work...
I'll probably end up stopping by home depot, or lowe's and looking at the rain gutter mesh. Unless I can find a website that has mesh comparible to Stillen's with a sheet available. That and glue/bondo work to hold it.
I'm looking to use my existing bumper, and not buying a new bumper. Not looking at throwing a lot of money to just look stock.
Sorry you had to go through this
.... This makes me even happier I cover my FMIC
always stay sleeper... I believe the T-Rex grille allows for a cut out oem grill and install..... Ill get back to ya.....
Ok found it....
http://cgi.ebay.com/ebaymotors/03-05...QQcmdZViewItem
Im almost positive this grill requires you to cut your OEM grill out because the grill is attached with black tooth clips to the Bumper.. Email the seller and ask.... Hope this helps......
always stay sleeper... I believe the T-Rex grille allows for a cut out oem grill and install..... Ill get back to ya.....Ok found it....
Hey check that out for now.. Ill still look around for more grilles to make certain you have more than one option....
Here is the T-Rex...
http://www.intensepower.com/tpobigr35.html
For info on it contact intensepower.... They will know if you could still install without OEM Black Grille.. Im still looking for more though..
Yup definately still looking, after looking at the t-rex grille's I still will probalby go with something else as I'd really like a grill style like Stillen's versus a vertical or horizontal type grille.
OK GOT IT!!
http://www.dragonautomotive.com/sp-b...461&CATALOG=59
Im almost positive this is the one where you have to cut out the OEM grille!! BrB.. Im gonna read up on it more..
YES IT IS CONFIRMED!!!
2003 to 2005 350Z Stainless Steel B-Cool Billets Grille ... PLEASE NOTE: Cutting of your existing grille is required to install this item.
I knew it!! I knew there was a grille you had to cut out the OEM grille..... bam there you are...
Go with the stillen then.. Call intensepower and ask if it can be installed on your car, they will know..
Check out the GrillCraft Grille for the 350Z you can install with or without cutting.
http://www.grillcraft.com/installs/i...install_id=167
Tochigi_236
Sep 27, 2015 03:40 PM
