Aerosync N-Style Front Bumper
Old Jan 18, 2007 | 01:32 PM
  #61
bb1314's Avatar
bb1314
da Terminator!
Any place sells this bumper for lower than $399 including shipping than this site?
http://www.gruppe-s.com/350z/zext.htm
Old Jan 18, 2007 | 01:39 PM
  #62
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I'll save you the search - no, no one does
that being said, save yourself the headache and do not order it with Greyhound shipping - they will butcher it. We used to ship Greyhound too because its so cheap. But, its not worth the hassle. Between all the damages, and the fact that you have to go pick the bumper up, its a giant pain in the ***.
We only ship it truck freight now - not a damaged one yet
Old Jan 18, 2007 | 01:46 PM
  #63
bb1314's Avatar
bb1314
da Terminator!
I put in my zip code in that website and I got the following...
PRODUCT ID PRODUCT NAME / DESCRIPTION QUANTITY PRICE
ASY-Z33-NSTYLE Aerosync N-Style Polyurethane Front bumper 1 $399.00/ea
SUB $399.00
SHIPPING (UPS Ground. Contact us for rush orders.) $0.00
TAX (CA Resident 8.25% sales tax) $0.00
TOTAL $399.00
Looks like they use UPS Ground.. it should be fine right?
Old Jan 29, 2007 | 08:15 AM
  #64
bb1314's Avatar
bb1314
da Terminator!
Hmm.. maybe it's just because I haven't seen the authentic Nismo V1 front bumper in person . The lip on the Aerosync looks a little thicker and doesn't stick out as much compared to the Nismo V1?
Old Jan 29, 2007 | 08:26 AM
  #65
Z1 Performance
Former Sponsor
it is identical in every way with the exception of the front badge provision
Old Jan 29, 2007 | 09:16 AM
  #66
bisdakr's Avatar
bisdakr
got mine from gruppe-s and they are shipping UPS it came in a beat up box but the bumper didn't suffer any damages. I've got a question on those who installed their bumper, is the bumper more to the left? I've got more space on the right headlight than my left.
Old Jan 30, 2007 | 04:13 PM
  #67
BigZ88's Avatar
BigZ88
it also appears as they have decided to "blend" the lip in as opposed to the look of the nismo where it looks like a stuck on lip
also, does aerosync have a website? like a manufacturer website?
Old Feb 1, 2007 | 04:38 PM
  #68
jmr0311's Avatar
jmr0311
bisdakr, I notice the same issue with the bigger opening on the right headlight on my bumper also but it doesn't look to bad.
Old Feb 2, 2007 | 01:59 AM
  #69
bisdakr's Avatar
bisdakr
oh okay, glad to hear it not just me. I didnt install it 100% just put two screws on side to have it on the car. also I haven't drilled to holes for the top mount with the plastic plugs it's got an uneven space there as of now but I'm sure it will go away once everything is painted and properly installed. Did you have do any modifications to the bumper? any sanding or grinding down? a person I talked to said this was a slap on right from the box so I haven't done any grinding or anything.
Old Mar 25, 2007 | 06:56 PM
  #70
bb1314's Avatar
bb1314
da Terminator!
When you guys installed the bumper, did you put any screws at the bottom of the bumper to hold that buttom plastic cover? I didn't do that and that plastic piece was starting to rub on the ground. Would 3M molding tape be strong enough to hold the 2 together?
Old Mar 25, 2007 | 07:00 PM
  #71
98Ekhatch's Avatar
98Ekhatch
yea same thing happened to me ...i used a dremel anf then put my stock screws in....you need to cause the wind will make it rubb the ground and i dont think 3m will hold..if anything just ziptie it..
Old Mar 25, 2007 | 09:17 PM
  #72
bb1314's Avatar
bb1314
da Terminator!
Dude.. I had the EXACT same situation. I'm kinda pissed that the body shop didn't take care of it when they said they would. It's a small thing, but kind of embarrassing when you're driving and it starts making weird scrapping noise all the sudden. I think I'll drill hoes and do the zip tie idea as well.
Old Mar 25, 2007 | 10:44 PM
  #73
350Z84's Avatar
350Z84
Man I am so tired of waiting on a good 06 lip, I think I might have to go this option. Love the look of this.
Old Mar 26, 2007 | 05:08 AM
  #74
devildoc's Avatar
devildoc
I had the same problem. I get off the interstate and I'm slowly driving next to some suv. I'm thinking " that suv sounds like crap!". As I pulled around a corner some cop tells me that I'm dragging something on the bottom of my car
Since then I've used double sided 3m tape with no problems
Old Mar 26, 2007 | 05:15 AM
  #75
bb1314's Avatar
bb1314
da Terminator!
So 3m tape works? Hmm... if so, I'll just skip the hassle of putting screws on. Thanks for the pointers!
Old Mar 26, 2007 | 05:38 AM
  #76
Z1 Performance
Former Sponsor
I would definitely not advise to you use 3M tape - you'll have to redo it every single time you change your oil and you'll end up replacing it once a year just from the dirt, grit and moisture that will collect.
best bet is drilling holes and using zip ties...it's a quick and easy solution that can be done at any time. Or, if you want to get a bit more involved, use the clips with nuts built in and a simple screw (available at any hardware store or autobody supply store).
Old Mar 26, 2007 | 11:08 AM
  #77
350Z84's Avatar
350Z84
For the reflectors on this bumper do you use the 03-05 reflectors or the 06 reflectors
Old Mar 26, 2007 | 03:29 PM
  #78
cubu's Avatar
cubu
i drilled holes in the bottom of mine and used the stock clips and bolts, were you guys able to fit the foam bumper support behind the bumper? i was not able to on mine
Old Mar 26, 2007 | 07:15 PM
  #79
azula's Avatar
azula
^my foam bumper brace fit, the problem i am have is my spash gaurds....i apologize if yall talked about this already, but mines pop out and my tires have eating away at them....i have an 04 z but i was adivsed to get the 06 splash guards because those will not pop out. has anyone upgraded to 06 splash gaurds with this bumper?
Old Mar 27, 2007 | 03:54 AM
  #80
Z1 Performance
Former Sponsor
you use the early reflectors (03-05)
if you cannot fit the foam, or your splash gaurds, your bumpers are not installed properly...I'd advise removing it, or loosening all the bolts, and from there start shifting things around till it fits. All of the components absolutely fit without incident.
