Double Sided Tape Failing
Old Feb 4, 2007 | 08:24 PM
35TH ANY's Avatar
35TH ANY
Default Double Sided Tape Failing
What should I use?
Old Feb 4, 2007 | 08:25 PM
Endless Shock's Avatar
Endless Shock
What type are you using... This should not happen unless you didnt clean both surfaces before applying the tape... 3M works great... The grey one...
Old Feb 4, 2007 | 10:33 PM
Cannysage's Avatar
Cannysage
even 3m isn't strong enough.. I've JB welded my damn side skirts.. they had hard time sticking so I'd recommend some kind or silicone.
Old Feb 5, 2007 | 03:21 AM
Mapleleaf's Avatar
Mapleleaf
Go to a Glass Shop ( Automotive ) and see if they will sell you a tube of Urethane best thing for sealing
Old Feb 5, 2007 | 05:10 AM
MustGoFastR's Avatar
MustGoFastR
Use a clear silicone RTV; works great in areas where the tape lets go. Thats what I use; 3M tape isn't great in areas of high tension where kit parts want to pull up. Just silicone it and use something to hold the part in the proper position until it cures (ussually overnight).
Old Feb 5, 2007 | 06:26 AM
THE TECH's Avatar
THE TECH
^ +1
Old Feb 5, 2007 | 07:46 PM
Spddracer's Avatar
Spddracer
3M makes stuff called adhesion promoter, It comes in little packets and looks like a alcohol wipe.
You can find it at almost all the paint supply stores.
Clean surface first, wipe with the adhesion promoter pad and I guarantee the 2 sided tape will hold. It works and works very well. Just be sure its where you want it when you stick it down
http://www.sherwin-automotive.com/pr...?product=29021
EnjukuRacing
Sep 30, 2015 06:55 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
