How to remove rear wing?
I did a search - no results. How do you remove the rear wing?
just taking a shot cause ive personelly never done it. remove the plastic underside of the trunk lid. should just be poppers that hold it in. after this you should see 4 nuts. take those off, lower the trunk and pull it up. but then your left with 4 holes in your trunk so hopefully your new spoiler will either cover up those, or bolt in the same but i know that 99% probably will NOT bolt in the same exact holes.
^I'm looking at a CF direct replacement wing. Hopefully it's the exact same size and mount points. Anyone else taken it off before?
You'll have double side tape all around the edge too. It's a ***** to get off.
any good way of covering the holes?
If the new spoiler covers the holes, just put some good double sided tape over them or put some silicon in the holes. |
So the general concensus is:
Take off plastic covering under the trunk. Take off four bolts that attach to the wing. Take off double sided tape. Does that sound right? |
sounds ALOT easier than it really is..
it took me several hours to get the tape off and using Goo-Off to get the left over adhesive off the stupid trunk.. i'd rather PAY someone to do it for me. or better yet. just swap trunk lids.. seriously a PITA.. here was my thread: https://my350z.com/forum/exterior-and-interior/101102-touring-wing-install-is-a-biatch.html |
Well I actually just took off the nismo wing and it was pretty easy.
Step1: Take the trunk plastic piece off and there are holes where they put the bolts in. Step2: They should be like a 10mm so use a socket wrench with a long socket. Step3: Put some duct tape around a flat head screw driver or something flat and use it to pry the spoiler up. The double sided tape is a BI@#T to get off the spoiler. I just pried it up then used a knife to cut it. Step4: Pull spoiler off and peel off the tape. Clean your trunk and you’re done. Hope it helps. The people who did mine had scratched my trunk when they installed it so I’ve gotta paint mine. :( |
it took me several hours to get the tape off and using Goo-Off to get the left over adhesive off the stupid trunk.. i'd rather PAY someone to do it for me. or better yet. just swap trunk lids.. seriously a PITA.. here was my thread: https://my350z.com/forum/showthread.php?t=101102 |
Originally Posted by bugsbbunny
Ahh...how does Goo Off work? Maybe I'll use a plastic scraper to get the sticky stuff off. Did you use your fingers?
fingers/nails, gotta use something soft else you'll scratch your hatch. goo off is rub on rag then rub in. and the adhesive turns into snot, then you just sorta.. roll it off. |
