Body damage repainted - paint doesnt match..
Old Mar 15, 2007 | 09:58 AM
sadclown's Avatar
sadclown
Default Body damage repainted - paint doesnt match..
Help plz, got rear ended and got hit on the drivers side door couple of weeks ago. Got car back but the rear bumper seems to be a little darker than the sides. What are the chances of the color matching perfectly?
2005 350z Vert LEmans Sunset
Help plz thanks in advance
Old Mar 15, 2007 | 10:01 AM
dmroberson's Avatar
dmroberson
Take it back to the shop, and have them fix it. A good paint shop should have been able to match it. I had a Radium (champagne) colored Sentra a while back, and the shop said that was a difficult color to match, cause of the flex in it, which made the color shift, depending on the light conditions, but they matched it perfectly.
Old Mar 15, 2007 | 10:05 AM
Cannysage's Avatar
Cannysage
post some pics, it's very hard to get a perfect match.. I've used 3 shops in the past and got it near perfect on couple of occassions, but usually off by a bit.. you'll get used to it.
Old Mar 15, 2007 | 10:28 AM
sadclown's Avatar
sadclown
i will have some pics later, thanks guys
Old Mar 22, 2007 | 09:45 PM
aren21's Avatar
aren21
All I know is my rear bumper/hatch/fenders, or hood/front bumper/ fender, dont match under certain lighting conditions. I think its because its a PPW (really hard to match) and the body uses different materials. The funny part is..... I have never got it repainted, its the original paint lol.
Old Mar 23, 2007 | 07:35 AM
cubu's Avatar
cubu
yup, paint on different materials will look different, they have to put stuff so the paint flexes on plastic parts, my gas door looks really off... plus our paint isn't the easiest to match
Old Mar 23, 2007 | 08:54 AM
DEATHBLOW's Avatar
DEATHBLOW
that is very true, it is hard to get paint to match but when i repaint cars i take anther part form the car and get the paint shop to match the color so that theres a closer match.but i would tell you to go get the car detailed really good and it should help the way it looks.
Old Mar 23, 2007 | 08:58 AM
03aeroZ's Avatar
03aeroZ
hey...i have an 03 lemans....the stealership just called in their "paint guys" and they matched the color on the spot...better than when it was brand new! only bad part was, i got rear ended again 3 weeks later....now i know where to go and what to have them do
Old Mar 23, 2007 | 03:13 PM
sadclown's Avatar
sadclown
thanks for help guys, went to the bodyshop and looked at some 07's they had (bodyshop owns the dealership as well)
Nice guys, but i did notice the 07s were a little off as well on the fender/back bumper.
They are going to try again.
There is a guy in Nor cal (buddy uses him for his top secret wide body g35) that has some kind of laser machine that matches the paint exactly , anyone know this?
So i have to drop the car off again next week. hopefully this time will work better.
Thanks again guys for all the help.
Old Mar 23, 2007 | 04:37 PM
joekool's Avatar
joekool
Here in Australia, you can buy already perfect matched tubs of paint for most cars, so paint shops don't need to do guesswork but buy already perfectly matched formula ready to go.
Old Mar 25, 2007 | 02:15 PM
jinsei888's Avatar
jinsei888
the only way for a body shop other than the dealer to matchthe paint is finding a shop that uses SPECIFICALLY, PPG Brand paint--not dupont, not all the other brands, ONLY PPG will match 100% perfectly, never fails. If you cant find a shop, then find a paint dealer in the area that can mix PPG Brand for you andthen bring it to the body shop of your choice and have them use the paint that you bought elsewhere; that is honestly your only way if you want 100% match guarantee. other brands and REALLY skilled shops can get as close to maybe 90-93% close to match, but only PPG will land that 100% factory tone where you cant tell the car was ever hit or repainted
Old Apr 1, 2007 | 04:16 PM
benwa02's Avatar
benwa02
you have personal experience painting the tri-color for the Zs?
my dads painting my bumper this week and did a few test panels with dupont...seems alrite, but we may try a test with PPG...its for an 06 PPW.
any tips you can give about doing this type of paint job or maybe the specific paint code for the PPW..i know there are such things as alternates?
Old Apr 1, 2007 | 04:21 PM
Miraclekidjr's Avatar
Miraclekidjr
Had the same problem with my SS
The color is off by 3 shades due to fading for 4 years
Old Apr 1, 2007 | 05:53 PM
jinsei888's Avatar
jinsei888
I usually work with Dupont as well, but had issues with paint matching also. I was recommended PPG by a couple dealer-bodyshop references and applied the paint in typical fashion, no unorthodox methods of paint spraying or curing times. I just went by OEM paint code when having the paint premixed at a local PPG paint vender shop and the oem paint match was DEAD on perfect. It's definitely worth your efforts, benwa02
Old Apr 2, 2007 | 03:27 AM
sokudo9l6's Avatar
sokudo9l6
so...i don't even have to bring my car into the shop if they use PPG paint?
Old Apr 2, 2007 | 05:01 AM
DXJP's Avatar
DXJP
Sorry but this is a crock. Do you even know whats sprayed on factory, I can tell you its crap alesco or rock and maybe even some DNT here in japan. I use standox and even sikkens and I can match any color right out of the can. I havnt see a factory pack for a nissan in years so thats probobly out to.
It sounds like it was a pannle shoot and they either over poured the toners OR they have the wrong variant. Again depending on the color, spray tactics play a role in it to.
Old Apr 24, 2007 | 03:45 PM
chromesilverz's Avatar
chromesilverz
Some shops will 'blend' the bumper color into the rest of the car. They do it by spraying thin coats of paint over a small area between the darker bumper and the rest of the car and re-clearcoat it. The gradual change in color gives the illusion that it one color.
Old Apr 24, 2007 | 07:08 PM
Armando's Avatar
Armando
PPG is the only paint that will match
Old Apr 24, 2007 | 07:19 PM
gthompson097's Avatar
gthompson097
I've sprayed alot of Dupont as well as some PPG and I've never really had a problem with either of them. Factory paint will fade over time if you leave it out in the sun alot, so if you use the factory code on old paint, of course it will look "off." It also depends on what type of paint it is. I have an Eclipse that I sprayed with Dupont ChromaBase and went back and did some touch-ups on the bumper with some leftover Nason and it looked off, so that will also play a roll in it.
350Z_Al
Oct 29, 2020 07:44 PM
Cashwin
Oct 1, 2015 06:36 AM
