bride seats ?'s
ok so on an impulse buy i bought some brides off a friend. the sliders that are on it are almost 100% most likely either universal or for something other than my car.
-for the universal sliders, do you just drill new holes in your floor?
-and how many of you guys wear the factory seatbelt with the seats instead of buying a harness?
well it has 1 slider on it...the other one he misplaced....its lookin like im gonna haveta buy new sliders anyway.......so therefore i can use the existing holes.....so i guess i just wanna know if the harnesses are used alot or if the factory seat belt is
Im using factory seat belts.. Throw the harnesses only on track days.. You will need a harness bar though or rollcage.. obviously..
Also, if you are using the 350z Z33 bride brackets/sliders you will be using the oem seat holes.. no drilling just bolt on.. check Leemik threads he has one of bride install.. should make it easier.. The install is easy though..
lol...tell me about it....but i got mine from someone who had NO idea what he had and therefore.....i got a good deal
but i have another ? now......both seats have sliders.....only one has the bracket which isnt for my car..so all i need is 2 brackets and hardware and im fine right?
also....can i use a different brand of bracket?, will they work with the sliders i have? and what will i have to do.....just drill new mounting holes?
thanks in advance
thanks in advance
well i have the bride sliders.....just not the brackets.....i just need mounting points from the original holes.....so i didnt know if any bracket would be fine and if i need to just drill out the holes
Ya might call or PM. Adam at Z1, I believe they sell bride and he can probably give you a better answer than us. When I bought mine used fortunately they had the correct sliders.
well to save time....i thought it would be easier to ask people who may have done this before.....im assuming the bracket brand doesnt matter other than the height since some people choose a different brand for just that reason.....the sliders are already bride sliders and mounted to the seat base...all i need is brackets....so i guess im ok...ill just buy some and drill the holes out for the hardware
Bride doesnt sell the sliders by itself. Their rail and bracket is in 1 unit and it'll have Bride tag on it also.
because the guy i bought it from lost one of the brackets but the slider is still in the seat base......the other bracket is still mounted to the seat....along with the 2nd bride slider
Bride doesnt sell universal sliders. Its either made specifically for your car or nothing at all.
