Need some relay wiring help
Old Jun 21, 2007 | 08:57 AM
myspivey's Avatar
myspivey
Default Need some relay wiring help
See this post for more info. Trying to figure out how to get this done, but having some issues.
http://www.the12volt.com/installbay/...TID~94926~PN~1
Old Jun 21, 2007 | 09:01 AM
sq40's Avatar
sq40
I posed an exact how to on this a couple of years ago, let me see if I can dig it up.
Old Jun 21, 2007 | 09:02 AM
sq40's Avatar
sq40
Hope this helps you;
https://my350z.com/forum/showthread....ighlight=Relay
Old Jun 21, 2007 | 09:34 AM
myspivey's Avatar
myspivey
So with this setup, the marker will be constant on till the turn signal hits at which point it will turn off? Ive got sort of a complex problem as these are for front marker strip lights. It has three lines coming out. One is ground. One is power for the marker, and the other is power for the turn. With your example it goes to just one that has a marker. This might help but its short of how mine is setup sort of. Your thoughts? Thanks ahead of time for the help!
350Z_Al
Oct 29, 2020 07:44 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
