Widebody Zx - My contribution to the Salad Bar Club!
Old Jul 24, 2007 | 10:28 AM
  #41
Chebosto's Avatar
Chebosto
I need more picts to prove that your salad is indeed Fresh.
Old Jul 24, 2007 | 10:34 AM
  #42
THE TECH's Avatar
THE TECH
That salad is rotten.
Old Jul 24, 2007 | 10:42 AM
  #43
buzzardmountain's Avatar
buzzardmountain
ROFL at the last two posts....
fresh salad.........rotten salad.
Old Jul 24, 2007 | 12:09 PM
  #44
Tac-M's Avatar
Tac-M
make sure you toss that salad !
Old Jul 24, 2007 | 12:30 PM
  #45
MustGoFastR's Avatar
MustGoFastR
I gotta side with the OP here on the issue of the emblem. It doesn't take being off-center much to make the emblem appear to be off center in relation to something further in the distance, like the rear window washer. If you look at it in relation to the licence plate indented area on the bumper below the emblem, it does, indeed, appear to be centered.
He IS busted on the fact that the emblem is mounted on the hatch, which is not part of the kit, therefore has no pre-molded area for the emblem to go, BUT he had to remove the Nissan hamburger from the hatch, which left two centered holes to line the Veilside emblem up over, so I find it highly unlikely that something so simple was screwed up.
To the OP: we really would like to see more pics of the car. As I stated earlier, which you conformed, the angle of the shot greatly exagerates the size of the wing. While I do have to question your taste based on the tail lights and the Honda plate frame (I Assume it's there for alignment purposes having to do with the cameras and you'll be replacing that), the Vs V3 kit is a good, agressive kit and looks good when done well, so put up some more pics and show your baby off! I'd like to see the rest of it, how it looks from the side with the wing, what wheels you have, etc. While the look isn't my cup of tea, I can respect the money and work that went into it. Nevermind the haters, but you have to admit you were asking for it by posting that one, unflattering pic.
Old Jul 24, 2007 | 12:54 PM
  #46
Wicked4u2c's Avatar
Wicked4u2c
Old Jul 24, 2007 | 02:33 PM
  #47
Nexx's Avatar
Nexx
Originally Posted by Wicked4u2c
not sure if the OP is hispanic or not.
Old Jul 24, 2007 | 02:39 PM
  #48
saberphx's Avatar
saberphx
Put some real wheels on that car and post more pics op! And return tail lights to original and tint them black.
  #49
BRONZEE's Avatar
BRONZEE
Club Moderator
Hmm, now depending what the OP uses his Z for, I was wondering if for track work, then that wing would provide a fair amount of downforce one would imagine.
Old Jul 24, 2007 | 02:50 PM
  #50
BaTMan_4's Avatar
BaTMan_4
Originally Posted by Driven1
Ok I definitely checked again and.....
1) You are centered behind the car. Please see your reflection in the pick in which .....
2) You are not in the shade but in direct sunlight unlike you stated
3) Also use other "center points" on the car as reference. Which, by the way all line up.
4) The markers may be on the body kit, but NOT on the hatch where you placed it.
and 5) You can assume I do have custom bodywork b/c all of my badging is centered. Just looks like an amateur did yours.
In conclusion, your rear badge is NOT center but off to the left.
And why do you need 2 rear cameras? one is plenty sufficient.
"2) You are not in the shade but in direct sunlight unlike you stated"
Old Jul 24, 2007 | 06:42 PM
  #51
stormcrow's Avatar
stormcrow
Originally Posted by doug
i did some photoshop work to see if the emblem is really off
first thing i did was draw a rectanglar bar so i could rotate the image so it was on the level.. as you can see both tail lights are now on a level..
then i made a triangle from the light to the emblem.. then i copied the layer and flipped it horizontally so its the same exact triangle.. and the emblem is indeed off
here is the psd with all the layers if you want to play with it yourself
http://www.skylineforums.org/myspace/MidnightZx.psd
doug - very nice work and a logical thought process... but, you are mistaken... if you look at your drawRing, you'll see that the triangle cuts more of the right bewbie off than the left... if you move the triangle to where it's evenly touching each bewbie, you will see that, indeed, the emblem is closer to being centered than what your image depicts...
PS - i think you should make the image bigger next time...
Old Jul 24, 2007 | 09:12 PM
  #52
Zazoozle's Avatar
Zazoozle
Aw ZUCrazy...its cute. If it makes you happy, then it was worth it. Dont listen to the haters. its very cute.
Old Jul 24, 2007 | 09:27 PM
  #53
zoni19's Avatar
zoni19
you should have gotten the big wing
Old Jul 24, 2007 | 10:06 PM
  #54
JMS71585's Avatar
JMS71585
The wing and those tails are bit too much. The VS wide body is a nice kit, but that wing and tails take away from the widebody kit. Good effort in making your Z stand out in a crowd, but change those tails to the new 06-07 LEDs and get a smaller wing...
Old Jul 24, 2007 | 11:31 PM
  #55
solidsnake's Avatar
solidsnake
One pic? What a tease
Take the liscense plate holder off the rear. Everyone will think its a HONDA from menlo honda
Old Jul 25, 2007 | 01:10 AM
  #56
Bboy Hustler's Avatar
Bboy Hustler
FLAME SUIT ON MAN!!! hahaha
Old Jul 25, 2007 | 01:26 AM
  #57
Cannysage's Avatar
Cannysage
"fly... on your way, like an eagle! fly as high... as the sun!!"
-Flight of Icarus- IRON MAIDEN
Old Jul 25, 2007 | 02:21 AM
  #58
joekool's Avatar
joekool
Zucrazy, why post only one pic and give people the opportunity to flame on an assumed basis.. Give us more pics so we can make a more accurate judgememnt noob... I mean you asked for our opinions and that's what you got.
Doug -> Your right triangle is too far to the right.. Therefore I will assume the emblem is dead centre.
Old Jul 25, 2007 | 02:25 AM
  #59
doug's Avatar
doug
its still off
Old Jul 25, 2007 | 05:48 AM
  #60
Ruthless18x's Avatar
Ruthless18x
