Help with "Personal" steering wheel
Old Aug 11, 2007 | 06:27 PM
synth19's Avatar
synth19
Default Help with "Personal" steering wheel
So a few buddies and myself did the steering wheel install today. We ran into a few problems. The good news is that we installed everything and the horn works (after ALOT of dremeling). A few issues:
1. VDC and SLIP Light stays on
2. Blinking airbag light on.
Adam @ Z1 provided the resister to override the airbag light, but I'm not exactly sure where it goes. Also, how can I get rid of the VDC and SLIP light? I understand that is it probably a wiring issue, but not sure whats the best way to tuck in the wires as room is VERY limited. Also, my wheel is slightly un-centered. Any recommendations to fix this? Some quick pics of the issues:
Other then all the warning lights staying on (VDC/SLIP/Airbag), the steering wheel feels great. it was a big difference from stock. I feel much more in control of the car. Glad I waited for the 330mm version of this wheel..
THANKS.
Old Aug 11, 2007 | 08:16 PM
Moroccan_Mole's Avatar
Moroccan_Mole
for the slip/vdc.
the little thing that turns where the hub is mounted to is 1 full revolution over, so the ecu thinks the steering angle is way off. edit you just have to turn it back the full revolution and you should be okay.
it looks like you have the resistors connected correctly for the airbag and they are supposed to be wound up exactly like that inside the hub. just make sure you have the connections tight.
Old Aug 11, 2007 | 08:19 PM
Moroccan_Mole
if you look at this thread:
https://my350z.com/forum/showthread....ighlight=wheel
look at post #13 (picture #15) that's what i'm talking about for the vdc/slip
Old Aug 11, 2007 | 09:41 PM
Chebosto's Avatar
Chebosto
blinking SRS airbag light is probably caused by you turning on the car before the resistors were 'seated'
you'll have to do the airbag reset procedure. make sure those two resistors are firmly in place.
as for the vdc slip lights. yea. do what mole said.
Old Aug 11, 2007 | 11:25 PM
drsifu's Avatar
drsifu
damn...everyone is quick to answer.
i'll reaffirm what the other two said.
my steering wheel is also off by 2-4 mm to the left. it's either that or a lot to the right.
i don't see how much more wiggle room there is as the splines on the short hub and the steering shaft can only line up in certain places. i tried spinning it, readjusting it....not much I could do.
might just go in to an alignment shop and have them center the wheel when they do the alignment.
Old Aug 12, 2007 | 07:02 AM
Moroccan_Mole
i got mine to line up perfect, the trick for me was driving straight up to where i was working without moving the wheel - i just parked and worked on it in the street. i have to turn pretty sharply to pull into my garage and i was having the same problem getting the wheel to line up straight it was either a few mm off to one side or like 1/2 turn to the other side.
Old Aug 12, 2007 | 07:23 AM
synth19's Avatar
synth19
what "little thing" do you mean the bolt?
Originally Posted by Moroccan_Mole
for the slip/vdc.
Old Aug 12, 2007 | 07:25 AM
Moroccan_Mole
that little white plastic thingy that turns
edit (when the hub is off)
Old Aug 12, 2007 | 07:37 AM
synth19's Avatar
synth19
^ gotta love the the technical terms. LOL! I'll take it off and look for it.
Old Aug 12, 2007 | 07:46 AM
Moroccan_Mole
right above your arrow, where the notch in the hub is.
Old Aug 12, 2007 | 07:47 AM
Moroccan_Mole
i think its called the spiral cable
Old Aug 12, 2007 | 10:21 AM
synth19's Avatar
synth19
so basically, I just need to turn it counter-clockwise the other way?
Old Aug 12, 2007 | 11:11 AM
Moroccan_Mole
you'll have to test it out.
try one full revolution counter clockwise first.
if that doesnt work 2 full revolutions clockwise.
Old Aug 12, 2007 | 11:37 AM
synth19's Avatar
synth19
^ thanks for all the help... going to try in another few hours when it gets a bit cooler.
Old Aug 12, 2007 | 12:56 PM
Kwame's Avatar
Kwame
I shrink wrapped the resistors as well to make sure that they would not move at all. Its not needed its just something extra I did.
Old Aug 12, 2007 | 02:02 PM
synth19's Avatar
synth19
Well, I tried the suggestions provided by Moroccan_Mole and took the car for a cruise. All lights disappeared except for the airbag code. I'm not sure if my resisters are faulty or not. Then I didn't like the position of the steering wheel so I decided to remove the steering wheel and hub to make a slight adjustment. No problem, right? wrong! VDC and Slip came back on! So a few more attempts of rotating the plastic piece in both directions, and still the lights stay on. I'm going to try it one more time and see what happens....
Old Aug 12, 2007 | 05:58 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
there are 2 plugs when you remove the factory wheel - one resistor goes in one, one goes in the other. Since its a resistor there is no polarity, and it does not matter what resistor goes where
As far as the SRS light, you'll need to do the SRS reset procedure on it to get the light to go away
The trick to installing these is making sure that either the wheel is perfectly straight, and not altered as you do the install, or, marking things off with some paint or a marker as you do it. If you turn the spiral cord one way or the other, the lights will come on and never go off. This is because the steering is tied to the ecu side and the ecu moniters steering wheel angle.
Old Aug 13, 2007 | 04:41 AM
synth19's Avatar
synth19
Thanks again Moroccan_Mole for the tips. I followed your suggestions again and the VDC and SLIP light went away yesterday night. I was hesitant in posting in case it magically came back today. But I'm happy to report that I drove the car to work (about 20 miles), and no issues! However, the flashing SRS still remains even after the reset procedure. I will probably bring the car to my friendly Nissan dealership to see if they can reset it. If not, then at least I will know it's probably the wiring, or maybe a faulty resistor.
Old Aug 13, 2007 | 04:48 AM
Z1 Performance
Former Sponsor
the reset procedure needs to be done exactly, and on time, or it won't work
When I installed my NISMO airbag wheel, it took me 3 times of doing it to get it right. If you have a cipher I think you can turn it off right from the software
Old Aug 13, 2007 | 02:14 PM
Moroccan_Mole
glad to see you got the vdc stuff worked out.
keep trying the reset procedures for the srs light, as adam said, the timing on it has to be EXACT.
