Gutting my car
Old Sep 3, 2007 | 01:04 PM
Devil Z's Avatar
Devil Z
Default Gutting my car
Does anyone know how much weight is saved by taking out all the carpet and plastic in the car? Especially in the back.
Also if I take out all the speakers and get rid of that ENTIRE thing behind the seats, does that saved at least 50 pounds?
Thanks!
Old Sep 3, 2007 | 01:22 PM
zzz350's Avatar
zzz350
Not sure, but if you remove the seats, steering wheel, windshield, and hatch glass, you will really bring the weight down. Also, removing the engine would really kick *** on weight savings.
Okay, don't get your undies in a bunch, I'm just kidding you. To answer your question, I have no idea.
Old Sep 3, 2007 | 01:55 PM
roast's Avatar
roast
the speakers don't weigh much at all.... the magnets on those things are tiny... but if you're going to take out the speakers you might as well take out the head unit... my only gripe with that is you lose your clock.
I would be guessing considering I haven't weighed most of the stuff I've taken out... but i doubt you will lose 50lbs from just carpet, speakers, that rear plastic section and all of the rear interior.... (assuming you've already ditched the spare)....
Old Sep 3, 2007 | 03:56 PM
groovin_350z's Avatar
groovin_350z
Sleeps in 350Z
+1 the carpet / speaker stuff barely saves u anything. taking out your stock seats and replacing them with some bucket seats would be a great start.
Old Sep 3, 2007 | 03:59 PM
Devil Z's Avatar
Devil Z
I'm thinking in the future:
Carbon Fiber Hatch w/Lexan Window
Carbon Fiber Roof
Carbon Fiber Doors
Carbon Fiber Hood
Carbon Fiber Fenders
Lightweight Battery
Old Sep 3, 2007 | 04:29 PM
creationv2's Avatar
creationv2
cf roof...if you really cf the roof and not an overlay....thatll be really expensive and id wonder about the structual integrity of the car.
Old Sep 3, 2007 | 04:30 PM
Devil Z's Avatar
Devil Z
Don't really care about the structural integrity as I'll be eventually building a cage.
Old Sep 3, 2007 | 04:33 PM
Jay'Z's Avatar
Jay'Z
Do a search on priscilla.. He did it and saved like 100pds i think.. Not sure...
Old Sep 3, 2007 | 05:43 PM
sofa king's Avatar
sofa king
Old Sep 3, 2007 | 05:58 PM
UGOTZ'D's Avatar
UGOTZ'D
but putting a cage in will prob eliminate any weight savings from doing cf on the roof. unless you were planning on putting a cage in anyways.
Old Sep 3, 2007 | 06:22 PM
05-Z's Avatar
05-Z
I posted this a while ago..
exterior
stock hatch: 77 lbs
hatch counterweight: 1.5 lbs
rear wiper and motor: 9 lbs
stock hood: 24 lbs
stock fenders: around 7.7 lbs each
headlight: 15 lbs each
interior
rear mat: 6 lbs
sound dampening "pads" in that space behind seats: about 5 lbs
shift ****: about 206 grams
leather heated seats: 50 lbs each
fabric seats: 37 lbs each
spare, jack, and tools: 40 lbs
headunit and speakers: about 7 lbs together
steel plate + bolts for subwoofer: about 5 lbs
suspension
stock sways: front 10.5 lbs and rear 4 lbs
stock spring and shock assembly: 10 lbs each
stock battery: 36 lbs
fluids
full tank of gas: 6.5 lbs x 17 gallons = 110.5 lbs
full tank of washer fluid: 8 lbs
exhaust
plastic intake manifold: 4 lbs
stock headers: 15.4 lbs
rear muffler: 34 lbs
mid pipe: 12 lbs
y-pipe: 16 lbs
catalytic converters: 23 lbs each
wheels
(depending upon air pressure, almost any nissan tire + rim combo will be around 40-60 lbs each)
17" base rims F: 17x7.5 = 23.26 lbs and R: 17x8.0 = 24.140 lbs
18" track rims F: 18x8.0 = 18.1 lbs and R: 18x8.5 = 18.62 lbs
18" perf/touring rims F: 18x8.0 = 27 lbs and R: = 18x8.0 = 27 lbs
18" LMGT rims F: 18x8.5 = 18.3 lbs and R: 18x9.5 = 18.8 lbs
19" LMGT rims F: 19 x 8.5 = and R: 19x9.5 = around 22 lbs
all 20 lug nuts: 2.6 lbs
drivetrain
stock clutch weight: 22.19 lbs
stock flywheel weight: 23 lbs
crank pulley: 6 lbs
Old Sep 3, 2007 | 07:17 PM
Ruthless18x's Avatar
Ruthless18x
^ Damn good info.
Old Sep 3, 2007 | 07:25 PM
roast's Avatar
roast
9lbs wiper and motor? damn that thing must be a lot heaver than i thought when i took mine off.... i would have guessed 4-5lbs...
Old Aug 14, 2008 | 04:17 PM
saberphx's Avatar
saberphx
Not expensive if you know how to mold dry carbon yourself. I've seen a carbon roof being done before too. (not on a z thought. The roof is aluminum anyway, your really not gonna save all that much, you can just cut off some supports on it instead from having a rollcage.)
Edit: wow didn't think this thread was so old, it was the first one to come up when I searched because I want to gut my car. oops
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
reno56
Interior
17
Nov 20, 2015 05:21 PM
