removing seats
Old Oct 1, 2007 | 07:06 AM
tquill's Avatar
tquill
Default removing seats
Ok I've already searched and didn't find anything... maybe I didn't search right and what not so I'm sorry if that's the case...
Anyway I have an 03 base and when I'm removing the seats the that's attached to the seat and floor board is held on the seat by a clip (which can be disconnected) and these special kidns of zip ties... Is it possible to remove those without breaking them or do I need to cut them to get them off?
Any help would be appreciated. Thanks guys.
Old Oct 1, 2007 | 07:23 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
You can remove the all the zip ties without cutting them. If you work them out carefully you can pop them out of the holes. I've removed and installed my seats 3 times using the same ties.
Old Oct 1, 2007 | 07:34 AM
joekool's Avatar
joekool
is it easy to take the seats out quick and easily??? I was hoping to take them out and properly vacuum the floor underneath and get any **** out of those hard to get spots and while I'm at it clean my seats properly.
Old Oct 1, 2007 | 07:48 AM
tquill's Avatar
tquill
Ok. I'm not sure if it will be too hard to explain... but how do you pop them out of the holes easily? It looks like the thing that pops through the hole... leaves two little plastic arms in the hole... do I need to get those arms out of the hole first or does that matter?
And to the above response... yes the seats are very easy to take out. Just four bolts and removing this wire that I'm having trouble with and you're done. Although I have an 03 base with non-powered seats so it may be harder for other with more options on the car.
Old Oct 1, 2007 | 03:05 PM
JDMFairladyZ33
The seats come out real easy. As for the ties I used a screw driver and some needle nose clamps. You're just going to have to work the tabs out pinch the arms close so that they'll slide back the other way. If you by chance break one it's not the end of the world. They're twist ties.
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
