Relocating the bright light switch....Can it be done (reasonable)
Old Oct 27, 2007 | 09:45 AM
The Brickyard Rat's Avatar
The Brickyard Rat
Default Relocating the bright light switch....Can it be done (reasonable)
I grew up driving cars where the high beam switch was on the floor...lower left side and switched with left foot.
I would much prefer to have it there for the Z.
Anyone know how easy/tough it would be to have the switch rewired to the floor?
Old Oct 27, 2007 | 10:20 AM
umsta's Avatar
umsta
I don't know but im sure it could be done with a lot of work. Is it that hard to just use the left lever? and if you drive stick then that would kind of be a hazard
Old Oct 27, 2007 | 11:15 AM
The Brickyard Rat
On curvy roads at night I tend to run in 3rd gear so not shifting that much. But I don't like reaching behind the steering wheel all the time to dim lights for on coming traffic.
Old Oct 27, 2007 | 03:06 PM
Sean's Avatar
Sean
The Clapper.
Old Oct 27, 2007 | 03:12 PM
failsafe306's Avatar
failsafe306
Why would you want to do that? That's 1970's Ford truck technology. I "grew up" driving a vehicle without power windows and door locks, but I sure as hell wouldn't want to convert my Z like that.
Old Oct 27, 2007 | 03:15 PM
Bolaz's Avatar
Bolaz
How hard is it just to tap the lever?
Old Oct 27, 2007 | 11:55 PM
token5gtd's Avatar
token5gtd
wouldnt be a bad idea for a nitrous system tho... of course after arming it with a switch
Old Oct 28, 2007 | 10:21 AM
The Brickyard Rat
Okay, I'm bored today so I'm gonna spend a few minutes "educating" you yahoos! LOL!
When aggressively driving twisty roads I like to have my left hand on the steering wheel and right hand on the gear shift.
When I have to hit the bright switch it means I have to (1) move right hand to steering wheel, (2) use left hand to operate the switch, (3) move left hand back to steering wheel, and (4) move right hand back to gear shift.
If I had the floor switch I'd (1) move foot to switch & operate and (2) move foot back to clutch.
That's half as many movements. Plus the foot movements are faster than hand movements. Plus I never have to release grip on steering wheel....which if I've got the wheel cranked around to navigate a curve is not a really good idea.
Simple economy of motion, folks.
Old Oct 28, 2007 | 10:30 AM
The Brickyard Rat
By the way, fail, I'm not talking about giving up any of the advantages of current car technology; I like the power everything, VDC, LSD, stero, Homelink, etc as much as anyone.
I simply want to add another switch for IMPROVED convenience & safety with my driving technique.
Old Oct 28, 2007 | 05:46 PM
merlin3's Avatar
merlin3
umm i dont know what kind of z your driving but i can easily turn brights on and off with my left hand and dont have to take my hand off the wheel.
Old Oct 28, 2007 | 05:52 PM
TheProfessional's Avatar
TheProfessional
It would be easier to setup a cadillac type light sensor in the front grille to sense oncoming traffic and tie into a relay that would dim the lights for you.
Old Oct 28, 2007 | 07:28 PM
The Brickyard Rat
"umm i dont know what kind of z your driving but i can easily turn brights on and off with my left hand and dont have to take my hand off the wheel.'
Let me see you do it when you've got, for example, the wheel cranked to the right when going around a curve.
Old Oct 28, 2007 | 07:29 PM
The Brickyard Rat
Professionial,
Thanks. I did not know such a devise was out there. Appreciate a useful idea.
Old Oct 29, 2007 | 05:40 AM
merlin3's Avatar
merlin3
you say when your driving that you don't have to worry about shifting because you're normally in 3rd gear so it wouldn't affect your foot. So if your not shifting why is your hand on the gear shift **** in the first place? You do know that you get much better control out of the car with two hands on the steering wheel right?
Old Oct 29, 2007 | 06:01 AM
350zHalleck's Avatar
350zHalleck
my old hotrod had this switch and I loved it. I think it is an interesting idea and would be interested in seing how easy it would be. also the cadillac idea sound like it would be nice. let us know what you come up with.
Old Oct 29, 2007 | 06:23 AM
TheProfessional
I think you can find those relays in a JC Whitney catalog.
Old Oct 29, 2007 | 06:47 AM
punish_her's Avatar
punish_her
It would be fairly simple with a foot tap switch. you would jsut need to clip the wires from that portion of the switch and relocate them to the floor foot switch. All you need is a hot and ground. Hell if you wired them in parallel you dont even have to loose the highbeam functionalilty of the switch up top.
Id say look up the wiring in the service manual. It would be simpiler to run 2 wire than totaly rewire your highbeams for a autosensing switch and relays.
To each his own, I personaly wouldnt do it though. Its your car, you have the tools now make it happen. Do a write up anlet every one know how it works. Hell with enough thought you can wire a button on the steering wheel.
Old Oct 29, 2007 | 09:55 AM
Get_Zwole's Avatar
Get_Zwole
when running hard you keep two hands on the wheel anyway. Removing your right hand only to shift then back to the wheel. keep your left hand at about 10 o clock and flick your fingers out it hits the lever and automatically nocks it into brights. Its really alot easier then changing alot of stuff to relocate in my opinion. Although the cadillac idea would rock.
Old Oct 29, 2007 | 10:11 AM
The Brickyard Rat
You guys who need two hands to steer are just whooses!!
LOL!
Appreciate the ideas, guys.
Old Oct 29, 2007 | 10:17 AM
punish_her's Avatar
punish_her
All else fails.... Rent-a-midget!
http://www.rent-a-midget.com/about.htm
http://www-scf.usc.edu/~rmsteven/
http://www.students.stedwards.edu/nspanna/
And when you cant get a midget... the next best thing!
HIRE A DWARF
http://www.dwarfentertainment.com/
Their pocketsized, convienient, and if you look hard enough Im sure you can even get JDM. Common who doesnt like a midget?
