How do I take off the plastic cap to access my low beam bulb?!!!
Old Nov 8, 2007 | 07:35 PM
SilverstoneZ's Avatar
SilverstoneZ
Default How do I take off the plastic cap to access my low beam bulb?!!!
I have an 03 Base. My drivers side light just burnt out.
I can access the back plastic cap covering the low beam after removing the inner fenderwell. I must have turned the cap 10 times and it will not come off.
Old Nov 8, 2007 | 07:49 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
it turns about a 1/4 turn or so then you have to pull it. It has little tabs/slots if that makes sense. It also has a rubber o-ring to kep out moisture so it's a snug fit. just turn and pull at the same time.
Old Nov 10, 2007 | 04:46 PM
SilverstoneZ
Thanks, took about 15 mins total to change the light. Just had to play witht hat part a bit to get it off.
Uriyo_
Sep 8, 2021 08:46 AM
350Z_Al
Oct 29, 2020 07:44 PM
aboodi
Oct 28, 2015 02:07 PM
