Nismo GT Shift Knob
Originally Posted by Sco2355
The bolt on top is what keeps the piece you hold and the actual screw on the shifter together. You need all three pieces in order for it to stay.
Should I remove the **** and retighten the bolt?
Then place the actual shift **** on the shifter and turn the NISMO etching to where ever you want it to face. After that take the top mounted bolt and screw it down as tight as you can (without stripping it). You can also use lock-tight on both pieces that screw to keep them locked down.
