AEM wideband bezel
Old Feb 21, 2008 | 06:16 PM
Chudson coupe's Avatar
Chudson coupe
Default AEM wideband bezel
I just got the AEM wideband gauge and it doesn't come close to matching my other two gauges. The problem is that the bezel (screw on piece that holds the face and glass on) its huge, the gauge is 52mm, are there any other guages that I could steal a bezel from that would fit? Has anyone else had this issue and what have you done to fix it?
Old Feb 21, 2008 | 06:33 PM
SpoilsofWar's Avatar
SpoilsofWar
It matched my Prosport gauges pretty well. I'm using the silver bezel ring with the black face.
What brand and model are your other gauges that you're trying to match to?
Old Feb 21, 2008 | 07:03 PM
Chudson coupe
they are cheap glowshift gauges, the bezel only sticks out about 1/8 of an inch from the face, I already ruined the silver bezel when I tried to trim it down to size haha, but I'm not going to attempt that on the black one.
Old Feb 23, 2008 | 07:33 AM
GreenGoblin's Avatar
GreenGoblin
i have the same one it doesstick out a bit question did you hook up the bluew wire for the data logging i have a utec I am not sure if this needs to be plugged into that?
350Shadow
Sep 22, 2015 08:30 AM
Calinismo350z
Sep 14, 2015 04:04 PM
speedsniper
Sep 14, 2015 08:46 AM
