Airbag Removal
Old May 27, 2008 | 12:29 PM
Navygolf13's Avatar
Navygolf13
Default Airbag Removal
Not saure if this is the right area to post this but I think it fits the best. I am going to be removing aribags from my Z both the passenger and driver side. I was just wondering what is the correct and safest way to do this. Any input on this would help. I searched and couldnt find anything about how to do the removal.
Thanks again!
Old May 27, 2008 | 12:56 PM
Z04's Avatar
Z04
i could not in a clear conscious tell you how to do this. plus it is illegal to remove front air bags (if that is what you are taling about) in a street car. look it up yourself or get a service manual to do this. now if it is a pure track car, then yeah i see no reason for an airbag at all.
Old May 27, 2008 | 01:56 PM
Navygolf13's Avatar
Navygolf13
We are building a racecar.....that being said, I know that it can be done. Where would I get a service auto manual?
Old May 27, 2008 | 02:36 PM
SpoilsofWar's Avatar
SpoilsofWar
Its extremely easy. I have done it, and could probably do both sides in about 15 minutes.
The drivers side is cake, just pull the steering wheel.
The passenger's side airbag is bolted into the dash from the underside, you have to remove the plastic trim piece that is on the underside of the dash, then just remove all those gold colored nuts you will see when you stick your head in the footwell and look up. I cant remember how many there are exactly, but its quite a few. Also there will be two wiring harness connectors on the passenger side airbag IIRC.
Disconnect battery before messing with any of this of course. Bottomline, you dont need any manual to do it, it is self explanitory when you look at it.
Old May 27, 2008 | 02:45 PM
Navygolf13's Avatar
Navygolf13
Honestly the concern was the airbag blowing....my brother-in-law was in the auto glass industry for a long time and he said he had heard that static electricity could blow them. If there is no battery though I cannot imagine them blowing....as for the driver side, how do they disconnect from the steering wheel? Or will that be self explanatory as well?
By the way thanks for the input....
Old May 27, 2008 | 02:50 PM
SpoilsofWar
I wouldn't worry about it... I really think people overestimate the sensitivity of airbags when it comes to accidental deployment.
In any case, I took no special precautions beside disconnecting the battery, and I had no issues.
As for the steering wheel airbag, there are two screws on the underside of the wheel (special torx head IIRC, and they are covered with plastic covers), remove those and you can remove the airbag.
If you have any other specific questions let me know, its been a while since I did it but I pretty much remember the process.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
