"M" Chassis brace removal
Old Jul 27, 2008 | 03:23 AM
HudsoN's Avatar
HudsoN
Default "M" Chassis brace removal
I hit something in the road and damaged my underbody brace mounting holes to the point where I cannot even thread in the bolts. Can I just remove this thing?
I heard that the G35 doesn't even have this brace.
If I bought the GTSPEC Ladder brace can I replace the stock brace? I know they aren't exactly in the same spot though.
Old Aug 1, 2008 | 04:46 PM
HudsoN's Avatar
HudsoN
Default ?
Anyone?
Old Aug 2, 2008 | 12:22 AM
bbs350z's Avatar
bbs350z
nope, that brace is pretty important if you care at all for structural rigidity. its there for a reason, please leave it there
Old Aug 3, 2008 | 10:42 PM
3fiddyz's Avatar
3fiddyz
replace it...It is 118 bucks from courtesy nissan in Texas! I bent mine too and it was easy to replace...Like someone else said...it is there for a reason!
G35's have them too...
Old Aug 17, 2008 | 11:20 PM
HudsoN's Avatar
HudsoN
I would just replace the brace but that is not the problem - the actual holes in the body are twisted / bent. Even with a new brace the bolts will not thread in! That is why this is such an issue. Expensive welding and cutting is involved to fix this.
Does anyone know if I can get the GTSpec Ladder brace and use it instead?
The general consensus seems to be do not remove the M brace, but with the GTspec installed would it be OK?
Old Aug 18, 2008 | 02:11 AM
Z04's Avatar
Z04
if the holes are bent like you said, nothing is going to fit there and you got worse problems than just the M brace being bad. you need to go to a shop that specializes in frame repairs
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Depravity
Oct 1, 2015 04:49 PM
