fuse
Old Aug 13, 2003 | 06:22 PM
fresno350's Avatar
fresno350
Default fuse
can anyone tell me which fuse in the fuse box down by the dead pedal is for the dome light?
Old Aug 13, 2003 | 08:09 PM
alphared's Avatar
alphared
the panel have a fuse map that tells you which fuse is for what part.
Old Aug 13, 2003 | 08:34 PM
fresno350's Avatar
fresno350
thank you.
Old Aug 14, 2003 | 05:19 PM
fresno350's Avatar
fresno350
Default didnt work?
there wasnt a spot on the lid for the dome light??? can anyone look in a shop schematic??
Old Aug 14, 2003 | 07:25 PM
ares's Avatar
ares
Veteran
wouldnt be under dome light, itd be like interior lights maybe, but probably something more general
Old Aug 14, 2003 | 09:08 PM
fresno350's Avatar
fresno350
Default every fuse
i tried every fuse under the fuse panel. i figured it was the one that said "room lights, and truck lights", but it wasnt. i think maybe it just goes through the BCM and shares a relay with another system if it has a fuse...
Old Aug 14, 2003 | 09:16 PM
ares's Avatar
ares
Veteran
its unlikely that it has a relay of its own, most likely tied into the computer with the alarm as there are sensors to tell it if the cars unlocked and all, plus it will go on when you unlock, but turn off later without being touched. much easier to do with circuitry than a simple relay.
you just gotta find the line out, but that doesnt mean the line out shouldnt go to a fuse before going to the cabin... there are various fuse boxes from what Ive read, honestly couldnt tell you where a single one of them is or whats in them, just seem to be fuse boxes scattered around the car.
Old Aug 15, 2003 | 03:53 AM
alphared's Avatar
alphared
did you check the fuse box in the engine compartment? its behind the battery.
Old Apr 13, 2005 | 08:24 PM
unstable's Avatar
unstable
when you find out where that fuse is please PM me, my dome and visor lights have been out for a week already and I can't find the freaking fuse either... grr...
Old Apr 14, 2005 | 02:29 AM
dirk's Avatar
dirk
are you sure the switch by the dome lights is not in the off position?
Dirk
Old Apr 14, 2005 | 04:00 AM
FIN350Z's Avatar
FIN350Z
POWER SUPPLY AND GROUND
Power is supplied at all times: through 10A fuse [No.21, located in the fuse block (J/B)]
Fuse block J/B: Behind the dash side lower LH finisher
Is the bulb OK ?
Old Apr 14, 2005 | 03:45 PM
unstable's Avatar
unstable
Is the bulb OK ?
Bulbs are fine, like I said its all four that are out... both dome lights and both visor lights, and I check all the fuse's... can't find a blown one anywhere...
Old Apr 14, 2005 | 03:47 PM
unstable's Avatar
unstable
Dirk
Thanks for you help but GOD DAMN that was a dumb question.... you should've just asked me if my battery was dead...
Old Apr 15, 2005 | 12:33 AM
FIN350Z's Avatar
FIN350Z
The interior room lamp system is not simple. I think for checking the whole circuit you'd have the interior room lamp system description in the service manual .... or visit the dealer service department.
Have you checked the input voltage at the bulb and also if the ground is missing at the bulb.
Old Apr 15, 2005 | 02:30 AM
dirk's Avatar
dirk
Is your Battery DEAD?
Dirk
Old Apr 15, 2005 | 02:53 AM
unstable's Avatar
unstable
Dirk
Hmm... No, but I just heard I may need a new "Flux Capasitor".
Old Apr 15, 2005 | 07:32 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
Ahh...those damn flux capacitors. Those are a ***** to change out. I may be thinking about a different car or even a boat but I think there is another fuse box like...behind/under the battery. I'm pretty sure it was the Z but it may have been something else.
Dr.Paulyy
Jul 29, 2019 07:45 AM
350Z Project X
Oct 17, 2015 05:16 PM
kyin
Oct 15, 2015 05:54 AM
Beater350z
Sep 9, 2015 03:36 PM
AP350z223
Sep 8, 2015 04:38 PM
