Nismo Rear V3 Bumper Help
Old Nov 16, 2008 | 01:48 PM
Zat20's Avatar
Zat20
Default Nismo Rear V3 Bumper Help
Hello, I am currently installing a nismo rear v3 bumper (the one on stock nismo's) on my enthusiast 350z. I was able to put the bumper on, however i have a couple of gaps underneath and i had to remove my impact strip foam & metal. I was wondering if anyone could help me out as to what parts I still need or if there is supposed to be the gaps. Thank you for your time and input.
Old Nov 17, 2008 | 07:21 AM
Done Deal DR's Avatar
Done Deal DR
Can you post a picture of the gaps? This is OEM, there should be no gaps.
Old Nov 17, 2008 | 07:41 AM
Changvi's Avatar
Changvi
+1.....Also, the impact beam and foam should never be removed for any reason or what so ever. They are on there for a reason, and Nismo Z also has impact beam and foam behind it to protect the car from low speed impact.
Old Nov 17, 2008 | 08:02 AM
OldDirty Z33's Avatar
OldDirty Z33
yup
Old Nov 17, 2008 | 08:09 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
that will save you 50lbs
Old Nov 17, 2008 | 11:38 AM
Zat20's Avatar
Zat20
I am in the process of ordering the nismo impact beam and foam since apparently it is a different size. The gaps i was referring to are the open spaces by the wheels and the black diffuser has holes but i dont have anything to connect them to.
Old Nov 23, 2008 | 01:11 AM
bensonlolo's Avatar
bensonlolo
ohhh, where can I order the nismo impact beam? I only took the foam out for my V3 rear bumper installation and it just fittt.
And for the open space n the 2 black hole of the underdiffuser, I saw there s some black long metal to connect them with somewhere in some nismo Z pic. However, i cant find a way to order those long metal. So i just let it empty.
hope this help, if u want, i can show you some pic of mine
Justin100
Nov 25, 2021 06:26 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
Stevo Z
Oct 3, 2015 09:14 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
