06 350Z Headlight Adjustment !
Does any one who did HID headlight adjustment can tell me which cut line should I have to measure for the height ?
I used 'HyperSprite Tech' website
http://www.hypersprite.com/auto/tech-z-003/index.asp
For 06 and up 350Z has different projector which gives you different shape of cut-off line. There are bottom and top cut-off lines.
This guy said that measure to the Hot-Spot with 26". I don't know that hot-spot will be the bottom or top cut-off line.
So which cut-off line should I use to measure the height of 26" ?
http://i5.photobucket.com/albums/y15...rofit2/sa7.jpg
Thank you.
Thank you.
If your looking at the cut off beam...the left side should be lower than the right , to avoid blinding incoming drivers. Im assuming 26 inches would be the same level at the headlights from the ground...so go with the right line.
Thanks
thank you for your tip. Right I knew that the left side of headlight should be a little lower than the right side. However, I have question about measuring the height of the beam. To measure the 26" height, which cut-off line should I measure? 'Bottom' or 'Top cut-off line ?
Thanks
Thanks
