Rice is nice. Overriding on/off underbody LED
Old May 18, 2009 | 01:33 PM
cheneymatthews's Avatar
cheneymatthews
Default Rice is nice. Overriding on/off underbody LED
So to many Z owners chagrin I installed a underbody LED kit. [insert barrage of negative opinions and rice mockery] My intentions were to have this illuminate when you press the door unlock/lock button on the remote, then fade off like the interior lights. So even though I wired the kit utilizing the dome supervision wire, the LED kits out there all require the on button to be pressed to activate the module. So the kit comes on... but you still have to be close enough to use the LED remote control to turn ON the lights. Anyone know how to bypass the on/off module requirement, so I can wire it to illuminate based on power supply versus the on/off switch?!?! I'd post pics... but with all the negativity on this forum.. I'll pass.
Old May 18, 2009 | 01:43 PM
Thermal1's Avatar
Thermal1
Pics! I would never do it to my car, but I want to seeeee! PM them to me
Old May 18, 2009 | 02:50 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
LED's aren't going to fade with the ramp voltage sent to them by the stock lights. They can be faded but it's going to need a dedicated driver circuit.
I tapped into the ground pins in each door to drive an LED steering network to turn my under the dash courtesy lights on. Without the steering network if the passenger gets out her door the system sees the ground on both doors and thinks that the driver is getting out with the key in the slot and starts the idiot chime going. A steering circuit is two diodes connected together, in this case cathode to cathode, and the anodes out to the door pins. The center junction between the two diodes is the output to the lights. It's a "T" circuit.
Edited to add: rice!
Old May 18, 2009 | 03:09 PM
Xzero's Avatar
Xzero
You might as well post pics. The flames are going to come regardless. I just want to see how the job looks! What color LEDs on what color car?
Old May 18, 2009 | 04:17 PM
kyx4n's Avatar
kyx4n
yup.. in for pics
Old May 19, 2009 | 11:12 AM
Waiz's Avatar
Waiz
+1
If you're gonna flaunt it, might as well own up to it.
Old May 19, 2009 | 11:15 AM
Spork's Avatar
Spork
I had this on my Celica. I had it riced out with a multicolor LED underbody kit, and they lit up like a courtesy light when the doors were unlocked, etc.
Old May 19, 2009 | 04:24 PM
juju's Avatar
juju
Hyperwhite that turns on with unlock and fades off would actually be pretty cool. I wouldn't do it though.
Old May 19, 2009 | 05:56 PM
kajuraelai's Avatar
kajuraelai
would never do this ...
Old May 19, 2009 | 11:30 PM
stylett9's Avatar
stylett9
i know i'm rice but i still like streetglow. haha
Old May 21, 2009 | 09:22 PM
cheneymatthews
Since everyone was so well behaved.. I'll post some rice pics and a link to a youtube video tomorrow.
Old May 21, 2009 | 09:30 PM
cheneymatthews
Hey Paul, thanks man... my problem isn't creating the power source fade, it's actually bypassing the LED control module which needs to be turned ON manually via remote, or button on control module. If these were LED's without computer modulation which changes the colors, sequences, and sound sensitivities then your method would certainly work... however since this control module receives the power input then requires the device to be powered on via a button rather than the actual power input I'm unable to do so. Hopefully my video post will help to clear this up!
Thanks again though.
Old May 22, 2009 | 09:47 AM
Mr.'s Avatar
Mr.
Nice to see someone is trying this. I wanted to do the same thing awhile ago with white LED's that would only turn on/off with lock/unlock. Always thought it'd be cool to walk toward a row of cars parked on a dark street, press unlock and see my car illuminate for a brief moment.
Old May 22, 2009 | 09:13 PM
cheneymatthews
Apparently youtube is updating right now.. so I'll have to wait on the video uploads. Here's some pics of the "white" led underglow!!
By the way fellas. I realize there's a few that want to drop their negative opinions even when nobody cares. So let it be known, the first time somebody says anything negative I'll pull the pics. This post is to show what it looks like, nobody cares whether you think it looks "ricey", if you don't like it don't do it to your car.... easy as that.
Old May 23, 2009 | 08:27 AM
Cass007's Avatar
Cass007
Prepare to pull the pics.... Not my style, but you should at least find a way to diffuse the light so it seems more evenly spread, not just hot spots IMO.
Old May 23, 2009 | 08:31 AM
Spork's Avatar
Spork
So ricey
Old May 23, 2009 | 08:39 AM
adamtaylorpcb's Avatar
adamtaylorpcb
who did the r8 mod?
for diffusing sand the bottom of the led bar to a light haze
Old May 23, 2009 | 12:40 PM
TSG-Z's Avatar
TSG-Z
Never thought I'd say this, but instead of doing those pointless mods IE; decals, groundlights, headlights, STOP! Save your money and get suspension, engine mods, or some rims.
Old May 23, 2009 | 12:51 PM
JSia's Avatar
JSia
nice stickers
Old May 23, 2009 | 02:21 PM
350zfun19's Avatar
350zfun19
what are you doing to your car? that looks so bad.
