Hid kit problem
Old Jun 21, 2009 | 09:44 AM
mrfobbyaccent's Avatar
mrfobbyaccent
Default Hid kit problem
I just installed my hid kit last night and the left light is like scattered in like three different spots. Has this happened to anyone before and if so how do I fix it. Thanks any advice would be great full.
Old Jun 22, 2009 | 04:34 PM
jenner1's Avatar
jenner1
One thing you might want to look at is at what angle the bulb is installed. By this I just mean at what rotational angle the insulated wire going to the top of the bulb is pointing. You should be able to insert the bulb two ways at a difference of 180 degrees where the wire going to the top of the bulb goes through a small slot in the housing. Although I have only seen this make any sort of difference in scatter pattern when hid bulbs are installed in a reflector housing as opposed to the projector housing in the z it is something you might want to look at. Check your right headlight and compare it to the left and make sure the wires are pointing the same way in your left housing.
Old Jun 22, 2009 | 11:07 PM
350POWER's Avatar
350POWER
the light patter is suk.......thats why i upgrade to 03-05 HID type, its little bit bitter light output but still, nothing better than 06+ HID type..........just 2cents
Uriyo_
Sep 8, 2021 08:46 AM
