Call me a ricer, I don't care~ ;)
Old Aug 11, 2009 | 08:53 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
INGS+1 N-Spec, a Modified Nismo V2, Airwalker, etc.. would of been good =/
Old Aug 11, 2009 | 09:38 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Originally Posted by Nexx
i would have gone with the cwest n1 for more flow but hey as long as that bumper is only for your TA events, i will let it pass.
+1....TONS of inlets in the front of that one.
... Man that Amuse looked so damn good on yur Z.
Old Aug 11, 2009 | 10:07 AM
jdhuegel1's Avatar
jdhuegel1
Not going to pretend that for one minute that I'm a fan of that bumper... But I think we can all agree that you are obviously about performance and looks.
Now, I'd probably puke on your hood if the rest of the car was stock! j/k
Old Aug 11, 2009 | 03:57 PM
zman1982's Avatar
zman1982
The Amuse was awesome, and this is disgusting
But if it works on the track for TA than function over form.
Old Aug 11, 2009 | 04:29 PM
maXmood's Avatar
maXmood
Under Boost!
i'm not gonna call u ricer before seeing the final product.
Old Aug 11, 2009 | 06:03 PM
killa.beez33's Avatar
killa.beez33
I don't get it, it seems like the Amuse has enough air openings maybe not?
May I ask why you decided to go this route? there are TONS of other front ends out there with more air openings and probably been tested for airflow and such, because I doubt the GTR knock off bumper was tested for aerodynamics or airflow, and etc...
I loved the way your car looked before but if function over form calls for it then it's a must. hehe
Old Aug 11, 2009 | 06:35 PM
2k6-z33's Avatar
2k6-z33
Old Aug 11, 2009 | 07:55 PM
Chebosto's Avatar
Chebosto
are you having troubles with cooling when drifting?
Old Aug 11, 2009 | 08:39 PM
SirSpeedyZ's Avatar
SirSpeedyZ
probably won't look that bad as long as you don't use the stupid black and whatever color paint scheme
Old Aug 11, 2009 | 08:40 PM
TheFarmer's Avatar
TheFarmer
Can't wait to see pics of it painted.
Old Aug 11, 2009 | 08:53 PM
juju's Avatar
juju
In for finished pics...
Old Aug 11, 2009 | 11:59 PM
Voboy's Avatar
Voboy
hope you have a nice paint scheme... good luck!
Old Aug 12, 2009 | 04:44 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
No, since drift courses are usually short, I don't get as hot as when I do TA.
Old Aug 12, 2009 | 12:38 PM
Chebosto's Avatar
Chebosto
are you :
1. using aftermarket fans?
2. running an undertray?
3. have a vented hood?
4. whats ur water/coolant mixture
5. what radiator u using?
Old Aug 12, 2009 | 12:50 PM
cheshirecat79's Avatar
cheshirecat79
at least fitment looks dead-on
Old Aug 12, 2009 | 04:25 PM
350ZthatsMe's Avatar
350ZthatsMe
looks good.. show pics when it's painted..
Old Aug 12, 2009 | 07:05 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
are you :
I'm trying to, but Sam@GTM wouldn't return my PMs.. HAHA~ He must be busy or on a vacation...
No undertray. I plan to create an airduct system similar to Amuse CSL. It will give the ram air effect for the intercooler and the radiator. Many of my friends with full out race cars swear by it.
Yes~!
50/50, but I might play with different ratio.. What do you recommand?
PWR 40mm. I know it's not big enough, but I'm looking into buying a two-pass radiator as you recommanded.
How are you doing with your cooling mods?
Old Aug 12, 2009 | 07:33 PM
  #38
Chebosto's Avatar
Chebosto
i'd first start running an undertray, you need to seal off the bottom of the car in order for the air flowing from the front bumper to be forced through the radiator and through your intercooler. by sealing that off, you're making the air go through, into the engine bay, and out the least resistance way, which is through your vented hood, as it should go.
before getting too ahead of yourself with the bumper (too late?) you should cut more into your hood and put a gurney flap in front of your opening to force the air to get sucked up and out of the engine...
pure racing? use distilled water and maybe Redline water wetter.
PWR 40mm. I know it's not big enough, but I'm looking into buying a two-pass radiator as you recommanded.How are you doing with your cooling mods?
i'm planning on trying out a cross flow radiator and /or dual pass.. make sure there isnt air in the system either.
i am thinking about doing the rear coolant pipe modification in which i get a bypass chamber /extra reservoir for coolant to get all the air out of the system all the time.
my next step is to get aftermarket fans, the lower thermostat, and possibly gut the back side of the engine fire wall area to get a gap from the hood and sheet metal..
if you still have your amuse front, see if you can get the esprit air ducts for the Z and install it higher up on the nose.. it will direct airflow to the top of your intercooler and to the radiator.
http://www.esprit.to/product_info.php?products_id=102
like this
Old Aug 12, 2009 | 07:35 PM
  #39
leeboyNY's Avatar
leeboyNY
Kimchi Eater
It's simple.. I didn't want to mess around with my Amuse, which is for my daily driving and car shows. It's nice to have a spare, whatever bumper, which I can do whatever I please... When you compete in drift and TA events, bumpers get Fed up!
Old Aug 12, 2009 | 07:44 PM
  #40
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Yeah, it's too late~ LOL~ HAHAH~~
I should have elaborated that I do have the front half of the undertray, because I was concerned about what you pointed out.
Soon or later, we are gonna end up gutting out everything and turn them into full out race cars.. LOL...
