Window tinting and the 350z question
Old Aug 17, 2009 | 06:07 PM
Entaille's Avatar
Entaille
you'll be fine. on top of that, if you weren't, your installer shouldn't be a douchebag and just replace whatever goes wrong if you didn't actually roll it down.
Old Sep 19, 2012 | 04:49 PM
Damosfla's Avatar
Damosfla
Default I did
I had an issue with my drivers side door only im guessing because I didn't open passenger side door, but it started out as a small bubble now it getting worse. The guy who done my tint told me it might happen because the way it automatically rolls down. Is there a fuse or way of temp. Disconnecting that.
Old Sep 19, 2012 | 08:12 PM
SR71's Avatar
SR71
Lead Super Moderator
As already stated
Originally Posted by dmroberson
It'll be fine, but if you want too, where the door switch is, the one that turns your dome lite on, when the door's open, take the screw out. Once you do that, the window will not bump up and down when u open and close.
My installer said give it 2 days, but they're pretty much set. The 2 days was for "just in case"
bcoffee20
Nov 19, 2015 06:39 PM
_koubie_
Sep 20, 2015 06:34 PM
