replacing shift knob
Old Oct 9, 2003 | 06:23 PM
tommym's Avatar
tommym
Question replacing shift ****
I have the nismo titanium gt shift ****. went to two dealers in northern va, and neither of them could remove the stock ****. One told me it wouldn't come off, and the other couldn't get it off. The one that couldn't get it off printed out a paper that said i have to lift the boot, put channel locks around the bottom, and twist the shift **** with another pair of pliars. I know some of you guys have removed them, so i am wondering if it is as much trouble as they claim.
Thanks.
Old Oct 11, 2003 | 06:40 AM
fairladyz33's Avatar
fairladyz33
before careful not to screw on it too tight when installin the Nismo GT shift ****, I turned it too tight and when I was driving, I think I broke the thread or something, it is lose now...so I gotta retire her for show use only.... just odn't want you to make the same mistake I did
Old Oct 11, 2003 | 07:17 AM
tommym's Avatar
tommym
i will keep that in mind if i ever replace it...can't get up the nerve to do it myself yet. When you replace yours, did you have to lift up the plastic area around the boot?
Old Oct 11, 2003 | 04:08 PM
jor8888's Avatar
jor8888
Mine came off easy for the NISMO GT URETHANE SHIFT ****
Old Oct 11, 2003 | 04:40 PM
jor8888's Avatar
jor8888
nope, but I like the boot lower so the bottom of my hand would not hit the top of the boot. I am still looking for a nice ring to go on top of the boot.
Old Oct 11, 2003 | 05:20 PM
failsafe's Avatar
failsafe
....for your health
I actually did mine yesterday. Had to lift the boot- the whole plastic piece including climate controls. Just grab the ring around the shift boot, nearest to the ebrake, and pull up towards the nav compartment.
Under the boot is some white felt- lift the felt material and there is a rubber boot beneath that. I then folded down the upper portion of the rubber boot so I could get the the vice grips on the stick itself- clamp the stick tightly (you don't want this to move). I then used another pair of vice grips on the original shift ****.
It was a pain in the *** to break it but it finally started to twist.
When I started to turn the shift **** I noticed the boot itself was twisting. I then had to loosen the boot by removing the 8 gold screws underneath so the boot could spin freely. Once this was done it came off pretty easily.
PM me if anyone has questions.
Old Oct 13, 2003 | 01:18 PM
alex30327's Avatar
alex30327
Where did you get the urethane shift ***. I just got the Titanium one and think I like the looks of your better.
Old Oct 13, 2003 | 09:32 PM
BJF2K's Avatar
BJF2K
is the shift boot suppose to be attached to the shift ****?
Old Oct 13, 2003 | 09:45 PM
MY350Z.COM's Avatar
you can get it at http://www.strictlyz.com http://www.courtesyparts.com http://www.performancenissanparts.com/
Old Oct 14, 2003 | 03:54 AM
Z350Lover's Avatar
Z350Lover
jor8888:
Is that urethane shift **** a 3 pieces **** as well? I meant the configuration of the gear ****.... same as the titanium ****?
thanks for your help mate!
cheers,
richie
Old Oct 14, 2003 | 10:13 AM
jor8888's Avatar
jor8888
From ebay
I dont know what u mean by 3 piece?
The boot can go all the way up into the **** I just like to have it lower so the bottom of my hand doesnt hit the boot.
Old Oct 14, 2003 | 10:26 AM
alex30327's Avatar
alex30327
Took my stock shift **** off last night and replaced it with the Nismo Titanium. I wasn't very dificult if you use a wrench. Took me about 30 min to complete the install.
Old Oct 14, 2003 | 10:44 AM
neur0sis's Avatar
neur0sis
None of those sites seem to have the same ****. :-\
Old Oct 14, 2003 | 10:49 AM
alex30327's Avatar
alex30327
Those places listed above have the titanium shift **** on their web site, but not the Urethane version. Its possible that they have it in stock and haven't put it on their web site as of yet. I went ahead and ordered mine form ebay.
ebay
http://cgi.ebay.com/ebaymotors/ws/e...&category=33703
Old Oct 14, 2003 | 04:53 PM
mberthia's Avatar
mberthia
jor8888,
What's that 'thing' in place of your radio ?
Old Oct 18, 2003 | 02:17 PM
350Zzzz's Avatar
350Zzzz
Professional
Do you have any pics; is there an easier way to remove the stock ****?
Removing the console cover was easy, it is removing the knod that is a pain.
Thanks.
G
Old Oct 19, 2003 | 10:08 AM
tommym's Avatar
tommym
Finally!!! I put the new shift **** on. It wasn't too bad once I got the pliars and channel locks to it. To you guys that have replaced it, how did you get the boot to stay up with the shifter?
Old Oct 21, 2003 | 06:27 AM
RJW0501's Avatar
RJW0501
Question. I installed the Nismo brushed aluminum ****. When installing, I put the black rubber finishing gasket on then the aluminum shifter ****...seems to sit in there to low...was ther suppose to be some sort of sleave that goes in betwwen shifter **** and rubber finishing gasket?
