Glove Box Cubby Swap...
Old Jan 28, 2010 | 10:51 AM
DelayedZ's Avatar
DelayedZ
Default Glove Box Cubby Swap...
I picked up another glove box (the one behind the passenger seat), so I can put it behind the drivers seat, my question is, for the glove box door, can I just pull the pins out with plyer's to swap the door to the other side? And can I pop the door panel open some how to switch the cable that holds the door up to the other side? I tried to split it open yesterday but was afraid of breaking it.
If you have no idea what I'm talkin about I'll try and take pics when I get home.
Old Jan 28, 2010 | 01:28 PM
$LiK RiK's Avatar
$LiK RiK
First off u can't swap doors from side to side,theres no hinge on that driver side. i recently put my amp & cap in there.Its the same on both sides, inside to bolt down the glove box but the door is mounted to plastic cover.jdm versions has the glove box on the other side but would leave u with same prob.
Old Jan 28, 2010 | 01:49 PM
halfrice's Avatar
halfrice
its doable, just putting in a glove box behind the drivers seat is easier than swaping from passenger to drivers side (which i did). You will not be able to use the string retractor unless you fabricate something to hold another. May need a few things from the other side depends what parts you got when you got your extra glove box.
Swapping from side to side will need alot more cutting, but thats just to fit the cover behind the drivers side on the passenger side. Easiest way to do it if money were not an object would be to get the panel off a jdm 350z because they are swapped from the factory.
on a side note, its something i would not do again lol (it was alot of work)
Old Jan 28, 2010 | 01:53 PM
DelayedZ's Avatar
DelayedZ
The hinge is there, its just two metal pins, you can fit them on either side.
And I got everything from the passenger side, bracket, full panel, glovebox itself, everything.
Old Jan 28, 2010 | 02:56 PM
$LiK RiK's Avatar
$LiK RiK
gl an post pics when done
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
